Out of memory crash repetier-server on raspberry pi
Repetier-server 0.90.7 on raspberry pi 3 (Raspian 9)
During a print, repetier-server was killed by the system and restarted with a "Out of memory: Kill process 680 (RepetierServer) score 867 or sacrifice child" log.
Logs :
/var/lib/Repetier-Server/logs/server.log
2018-10-23 18:07:52: start printjob 34505_manche +4 on printer HD
2018-10-23 18:07:53: LUA job rendering.render#{"id":8,"image":"/var/lib/Repetier-Server/printer/HD/jobs/00000008_34505_manche +4_l.png","layer":"/var/lib/Repetier-Server/printer/HD/jobs/00000008_34505_manche +4.layer","list":"jobs","slug":"HD"}
2018-10-23 18:09:15: Reading configuration file ...
Input file: /var/lib/Repetier-Server/printer/HD/jobs/00000008_34505_manche +4.layer
Rendering shadows ...10.6502 seconds.
Rendering gcode ...54.7037 seconds.
Number of end triangles: 275352
Number of normal triangles: 9381918
Rendering background ...
Time for raytracing: 15.0837 seconds.
images stored.
Computation time: 82.6972 seconds
2018-10-24 00:14:25: error:WifiManager::scanMode:System exception
2018-10-24 00:16:51: error:WifiManager::scanMode:System exception
2018-10-24 00:16:54: error:WifiManager::scanNetworks:System exception
2018-10-24 00:17:58: error:WifiManager::scanMode:System exception
2018-10-24 00:17:59: error:WifiManager::scanNetworks:System exception
2018-10-24 00:19:01: error:WifiManager::scanMode:System exception
2018-10-24 00:19:01: error:WifiManager::scanNetworks:System exception
2018-10-24 00:20:03: error:WifiManager::scanMode:System exception
2018-10-24 00:20:04: error:WifiManager::scanNetworks:System exception
2018-10-24 00:21:07: error:WifiManager::scanMode:System exception
2018-10-24 00:21:08: error:WifiManager::scanNetworks:System exception
2018-10-24 00:22:11: error:WifiManager::scanMode:System exception
2018-10-24 00:22:13: error:WifiManager::scanNetworks:System exception
2018-10-24 00:23:18: error:WifiManager::scanMode:System exception
2018-10-24 00:23:22: error:WifiManager::scanNetworks:System exception
2018-10-24 00:24:31: error:WifiManager::scanMode:System exception
2018-10-24 00:24:34: error:WifiManager::scanNetworks:System exception
2018-10-24 00:25:49: error:WifiManager::scanMode:System exception
2018-10-24 00:26:03: error:WifiManager::scanNetworks:System exception
2018-10-24 00:26:28: Start logging...
2018-10-24 00:26:28: Imported external command Shutdown Server
2018-10-24 00:26:28: Imported external command Reboot Server
/var/log/syslog
Oct 24 00:17:16 Repetier-Server CRON[8933]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094270] usbhid-ups invoked oom-killer: gfp_mask=0x14000c0(GFP_KERNEL), nodemask=(null),  order=0, oom_score_adj=0
Oct 24 00:26:26 Repetier-Server kernel: [102028.094285] usbhid-ups cpuset=/ mems_allowed=0
Oct 24 00:26:26 Repetier-Server kernel: [102028.094300] CPU: 2 PID: 814 Comm: usbhid-ups Tainted: G         C      4.14.77-v7+ #1154
Oct 24 00:26:26 Repetier-Server kernel: [102028.094303] Hardware name: BCM2835
Oct 24 00:26:26 Repetier-Server kernel: [102028.094324] [<8010ff30>] (unwind_backtrace) from [<8010c174>] (show_stack+0x20/0x24)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094334] [<8010c174>] (show_stack) from [<80788e64>] (dump_stack+0xd4/0x118)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094346] [<80788e64>] (dump_stack) from [<802249e0>] (dump_header+0xac/0x208)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094356] [<802249e0>] (dump_header) from [<80223d48>] (oom_kill_process+0x478/0x584)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094364] [<80223d48>] (oom_kill_process) from [<802246a8>] (out_of_memory+0x124/0x334)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094374] [<802246a8>] (out_of_memory) from [<8022a180>] (__alloc_pages_nodemask+0x1060/0x11d8)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094383] [<8022a180>] (__alloc_pages_nodemask) from [<8022a318>] (__get_free_pages+0x20/0x6c)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094393] [<8022a318>] (__get_free_pages) from [<805c2be0>] (usbdev_ioctl+0xfb0/0x1ac8)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094404] [<805c2be0>] (usbdev_ioctl) from [<8029eab0>] (do_vfs_ioctl+0xac/0x7c4)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094412] [<8029eab0>] (do_vfs_ioctl) from [<8029f20c>] (SyS_ioctl+0x44/0x6c)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094421] [<8029f20c>] (SyS_ioctl) from [<80108000>] (ret_fast_syscall+0x0/0x28)
Oct 24 00:26:26 Repetier-Server kernel: [102028.094424] Mem-Info:
Oct 24 00:26:26 Repetier-Server kernel: [102028.094436] active_anon:107744 inactive_anon:107805 isolated_anon:0
Oct 24 00:26:26 Repetier-Server kernel: [102028.094436]  active_file:250 inactive_file:294 isolated_file:0
Oct 24 00:26:26 Repetier-Server kernel: [102028.094436]  unevictable:0 dirty:0 writeback:0 unstable:0
Oct 24 00:26:26 Repetier-Server kernel: [102028.094436]  slab_reclaimable:1824 slab_unreclaimable:5291
Oct 24 00:26:26 Repetier-Server kernel: [102028.094436]  mapped:1421 shmem:2585 pagetables:955 bounce:0
Oct 24 00:26:26 Repetier-Server kernel: [102028.094436]  free:5169 free_pcp:2 free_cma:1271
Oct 24 00:26:26 Repetier-Server kernel: [102028.094444] Node 0 active_anon:430976kB inactive_anon:431220kB active_file:1000kB inactive_file:1176kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:5684kB dirty:0kB writeback:0kB shmem:10340kB writeback_tmp:0kB unstable:0kB all_unreclaimable? yes
Oct 24 00:26:26 Repetier-Server kernel: [102028.094456] Normal free:20676kB min:16384kB low:20480kB high:24576kB active_anon:430976kB inactive_anon:431220kB active_file:1040kB inactive_file:1396kB unevictable:0kB writepending:0kB present:970752kB managed:949448kB mlocked:0kB kernel_stack:1208kB pagetables:3820kB bounce:0kB free_pcp:8kB local_pcp:0kB free_cma:5084kB
Oct 24 00:26:26 Repetier-Server kernel: [102028.094458] lowmem_reserve[]: 0 0
Oct 24 00:26:26 Repetier-Server kernel: [102028.094466] Normal: 1500*4kB (UMEC) 294*8kB (UMEC) 103*16kB (UMEC) 26*32kB (EC) 12*64kB (UEC) 8*128kB (UEC) 1*256kB (U) 0*512kB 2*1024kB (UE) 1*2048kB (U) 1*4096kB (C) = 21072kB
Oct 24 00:26:26 Repetier-Server kernel: [102028.094513] 3410 total pagecache pages
Oct 24 00:26:26 Repetier-Server kernel: [102028.094517] 234 pages in swap cache
Oct 24 00:26:26 Repetier-Server kernel: [102028.094521] Swap cache stats: add 27158, delete 26924, find 1712/3144
Oct 24 00:26:26 Repetier-Server kernel: [102028.094523] Free swap  = 0kB
Oct 24 00:26:26 Repetier-Server kernel: [102028.094525] Total swap = 102396kB
Oct 24 00:26:26 Repetier-Server kernel: [102028.094529] 242688 pages RAM
Oct 24 00:26:26 Repetier-Server kernel: [102028.094531] 0 pages HighMem/MovableOnly
Oct 24 00:26:26 Repetier-Server kernel: [102028.094533] 5326 pages reserved
Oct 24 00:26:26 Repetier-Server kernel: [102028.094536] 2048 pages cma reserved
Oct 24 00:26:26 Repetier-Server kernel: [102028.094539] [ pid ]   uid  tgid total_vm      rss nr_ptes nr_pmds swapents oom_score_adj name
Oct 24 00:26:26 Repetier-Server kernel: [102028.094558] [   90]     0    90     8779     1229      15       0       59             0 systemd-journal
Oct 24 00:26:26 Repetier-Server kernel: [102028.094564] [  128]     0   128     3703       30       9       0      159         -1000 systemd-udevd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094571] [  278]   100   278     4320       14       9       0       95             0 systemd-timesyn
Oct 24 00:26:26 Repetier-Server kernel: [102028.094577] [  322]     0   322     1324       16       7       0       38             0 cron
Oct 24 00:26:26 Repetier-Server kernel: [102028.094583] [  327]     0   327    13255        0      18       0      349             0 ModemManager
Oct 24 00:26:26 Repetier-Server kernel: [102028.094589] [  330] 65534   330     1324        4       6       0       56             0 thd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094596] [  333]   108   333     1634       47       7       0       68             0 avahi-daemon
Oct 24 00:26:26 Repetier-Server kernel: [102028.094601] [  336]     0   336     5937       19       9       0      144             0 rsyslogd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094608] [  342]   105   342     1659       80       7       0       74          -900 dbus-daemon
Oct 24 00:26:26 Repetier-Server kernel: [102028.094613] [  359]   108   359     1601        5       5       0       72             0 avahi-daemon
Oct 24 00:26:26 Repetier-Server kernel: [102028.094620] [  371]     0   371    25545      232      26       0      284             0 NetworkManager
Oct 24 00:26:26 Repetier-Server kernel: [102028.094625] [  373]     0   373     1728       20       8       0       70             0 systemd-logind
Oct 24 00:26:26 Repetier-Server kernel: [102028.094631] [  389]     0   389     9415        1      13       0      153             0 polkitd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094637] [  429]     0   429     2418       59       8       0       88             0 wpa_supplicant
Oct 24 00:26:26 Repetier-Server kernel: [102028.094642] [  430]     0   430     1661        2       8       0      179             0 dhclient
Oct 24 00:26:26 Repetier-Server kernel: [102028.094648] [  448]     0   448      524        0       5       0       34             0 hciattach
Oct 24 00:26:26 Repetier-Server kernel: [102028.094655] [  453]     0   453     1818        0       8       0       84             0 bluetoothd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094661] [  613]     0   613      721       12       5       0       73             0 dhcpcd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094666] [  635]     0   635     1049        0       7       0       35             0 agetty
Oct 24 00:26:26 Repetier-Server kernel: [102028.094673] [  649]     0   649     2552        0       8       0      138         -1000 sshd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094678] [  675]     0   675    11763        6      14       0      266             0 nginx
Oct 24 00:26:26 Repetier-Server kernel: [102028.094684] [  676]    33   676    11797        2      15       0      308             0 nginx
Oct 24 00:26:26 Repetier-Server kernel: [102028.094690] [  677]    33   677    11797       18      15       0      297             0 nginx
Oct 24 00:26:26 Repetier-Server kernel: [102028.094696] [  678]    33   678    11797       18      15       0      297             0 nginx
Oct 24 00:26:26 Repetier-Server kernel: [102028.094701] [  679]    33   679    11797       22      15       0      297             0 nginx
Oct 24 00:26:26 Repetier-Server kernel: [102028.094707] [  680]   109   680   296805   211632     498       0    16085             0 RepetierServer
Oct 24 00:26:26 Repetier-Server kernel: [102028.094713] [  681]     0   681     1266        0       6       0       55             0 repetier_ui.sh
Oct 24 00:26:26 Repetier-Server kernel: [102028.094719] [  682]     0   682     2082        2       9       0       92             0 sudo
Oct 24 00:26:26 Repetier-Server kernel: [102028.094724] [  686]     0   686     5964       27      12       0     1140             0 python
Oct 24 00:26:26 Repetier-Server kernel: [102028.094730] [  687]     0   687     6620       51      16       0      296             0 nmbd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094736] [  713]     0   713    10164       89      24       0      411             0 smbd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094742] [  714]     0   714     9663       44      22       0      417             0 smbd-notifyd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094748] [  715]     0   715     9661       43      21       0      417             0 cleanupd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094754] [  717]     0   717    10166       84      24       0      397             0 lpqd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094760] [  814]   111   814      668       25       6       0       41             0 usbhid-ups
Oct 24 00:26:26 Repetier-Server kernel: [102028.094766] [  824]   111   824     1246       17       7       0       58             0 upsd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094772] [ 1402] 65534  1402     2308       22       9       0       71             0 dnsmasq
Oct 24 00:26:26 Repetier-Server kernel: [102028.094778] [28113]     0 28113     3761       69      12       0      175             0 cupsd
Oct 24 00:26:26 Repetier-Server kernel: [102028.094784] [28114]     0 28114     8824        0      16       0      242             0 cups-browsed
Oct 24 00:26:26 Repetier-Server kernel: [102028.094790] Out of memory: Kill process 680 (RepetierServer) score 867 or sacrifice child
Oct 24 00:26:26 Repetier-Server kernel: [102028.094868] Killed process 680 (RepetierServer) total-vm:1187220kB, anon-rss:846528kB, file-rss:0kB, shmem-rss:0kB
Oct 24 00:26:26 Repetier-Server kernel: [102028.333858] oom_reaper: reaped process 680 (RepetierServer), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Oct 24 00:26:26 Repetier-Server systemd[1]: RepetierServer.service: Main process exited, code=killed, status=9/KILL
Oct 24 00:26:26 Repetier-Server systemd[1]: RepetierServer.service: Unit entered failed state.
Oct 24 00:26:26 Repetier-Server systemd[1]: RepetierServer.service: Failed with result 'signal'.
Oct 24 00:26:26 Repetier-Server systemd[1]: RepetierServer.service: Service has no hold-off time, scheduling restart.
Oct 24 00:26:26 Repetier-Server systemd[1]: Stopped Repetier-Server 3D Printer Server.
Oct 24 00:26:26 Repetier-Server systemd[1]: Starting Repetier-Server 3D Printer Server...
Oct 24 00:26:28 Repetier-Server systemd[1]: Started Repetier-Server 3D Printer Server.
  • Anything special you did? Do you have a webcam or often wifi disconnects?
    Normally the server is using maybe 20MB so either one action causes a memory leak under some conditions or you did something using much memory, also normally big tasks are done outside.
    Was the server running for a long time already?
    I ask just to find a hint when the problem exactly occurs so I get a chance to find it.
  • The webcam was disconnected.
    The server was running for 2 or 3 days max.
    The raspberry is connected to the lan by ethernet. The wifi (hotspot done by repetier) only manages two connected sockets.
    top -H :
      PID USER      PR  NI    VIRT    RES    SHR S %CPU %MEM     TIME+ COMMAND
    32014 pi        20   0  390936  98500  58552 S  5,6 10,4   0:15.72 chromium-browse
    32531 pi        20   0    8384   3316   2696 R  2,6  0,3   0:00.31 top
     9004 repetie+   0 -20  329812  56200  15844 S  1,6  5,9  17:52.48 RepetierServer
     9017 repetie+   0 -20  329812  56200  15844 S  1,0  5,9   0:33.21 RepetierServer
    29455 repetie+   0 -20  329812  56200  15844 S  1,0  5,9   0:27.09 RepetierServer
    28308 repetie+   0 -20  329812  56200  15844 S  0,7  5,9   6:01.91 RepetierServer
    28309 repetie+   0 -20  329812  56200  15844 S  0,7  5,9   6:28.15 RepetierServer
    30820 repetie+   0 -20  329812  56200  15844 R  0,7  5,9   6:00.44 RepetierServer
    24300 repetie+   0 -20  329812  56200  15844 S  0,7  5,9   0:07.68 RepetierServer
    32448 repetie+   0 -20  329812  56200  15844 S  0,7  5,9   0:00.58 RepetierServer
       68 root      20   0       0      0      0 S  0,3  0,0   0:33.28 mmcqd/0
      226 root      20   0       0      0      0 S  0,3  0,0   0:17.59 brcmf_wdog/mmc1
      371 root      20   0  102180   5556   4420 S  0,3  0,6   0:15.76 NetworkManager
      415 root      20   0  102180   5556   4420 S  0,3  0,6   0:08.09 gdbus
      814 nut       20   0    2672    100      0 S  0,3  0,0  11:37.72 usbhid-ups
     9003 repetie+   0 -20  329812  56200  15844 S  0,3  5,9   1:17.08 RepetierServer
     9006 repetie+   0 -20  329812  56200  15844 S  0,3  5,9   0:26.61 RepetierServer
    28307 repetie+   0 -20  329812  56200  15844 S  0,3  5,9   6:11.90 RepetierServer
    28310 repetie+   0 -20  329812  56200  15844 S  0,3  5,9   2:12.27 RepetierServer
    28311 repetie+   0 -20  329812  56200  15844 S  0,3  5,9   6:35.14 RepetierServer
    24302 repetie+   0 -20  329812  56200  15844 S  0,3  5,9   0:15.00 RepetierServer
    29503 repetie+   0 -20  329812  56200  15844 S  0,3  5,9   0:07.14 RepetierServer
    31829 pi        20   0  591976 123036 103352 S  0,3 13,0   0:01.09 Chrome_IOThread
    I see a process "chromium-browser" is-it normal? Why a local browser ?
  • The chromium browser is used for the touchscreen on your pi. If you have none, you should disable it. If you use latest image see here:
    https://www.repetier-server.com/knowledgebase/prepare-for-prusa-mk3-on-raspberry-pi-zerow-rambo-einsy-board/
    on how to disable it. Otherwise edit /home/pi/.bashrc at end you see
    if ! pgrep "xinit" > /dev/null
    then
        sudo chmod 660 /dev/tty*
        xinit -- -nocursor 2> /dev/null > /dev/null &
    fi
    The xinit line is starting xserver with chromium. Put a # in front to comment it and reboot.
    Memory usage seems to differ a lot.
    13 days up, some prints on a pi zero (512MB):
      630 repetie+   0 -20  193304  27444  16068 S  0.3  6.2  39:51.20 RepetierServer
    4 days up multiple printers Pi3, 1GB:
     1108 repetie+   0 -20  280192  21120  13512 S  0.3  2.2   4:43.45 RepetierServer
    For clearance - virtual memory is not what is used. RES or MEM% is what the software actively is using. VIRST includes shared memory and shared libraries. Also all threads use the same memory so it is not 15 * RES in your case.
    Speaking of threads I see 15. My pi zero no external connections has 9. Each connection adds one thread and each printer 2 more threads. Do you have several printers connected? Would at least explain you are using 56MB RAM.
    One thing I can think of is that one communication thread does not close when connection is closed (e.g. browser closed, pc shut down). If it still stores missing data to send it would at some point use the memory. But all connections have a timeout so that is not happening as fas as I can see.
    Will keep an eye on this.
  • Ok, I disable xserver
    I have only 1 printer + 1 web connection + websockets to send gcode when I push physical buttons on the rapsberry (for extracting/pushing filament or pause/cancel print job).
    I will check if websocket connection are closed. But when the server crash, no buttons was pushed.
    Thanks a lot.
  • So you have a program watching pi pins and sending commands. Can you post it so I can see if that can cause a problem. Just for sending a command on button push a websocket is a bit overkill. Here a simple api call would be more then enough.
  • https://github.com/fthome/repetier_ui
  • This night, I did a test :
    after a new boot, a send a print and every hour I send a "free -m" to a file.
    21:00 : 60MB used
    22:00 : 66MB used
    23:00 : 71MB used
    00:00 : 150 MB used
    01:00 : 250 MB used
    02:00 : 338 MB used
    03:00 : 353 MB used
    04:00 : 354 MB used
    05:00 : 354 MB used
    06:00 : 354 MB used
    07:00 : 355 MB used
    08:00 : 361 MB used
    It is the processus Repetier-Server who use the memory
    During this period I've just print a job :
    2018-10-25 20:11:06: Starting web server ...
    2018-10-25 20:11:06: Webserver started.
    2018-10-25 20:11:07: Connection started: HD
    2018-10-25 20:11:07: Reset printer HD
    2018-10-25 20:11:08: New SSID Not Connected
    2018-10-25 20:13:48: Activating access point
    2018-10-25 20:15:28: Job created: /var/lib/Repetier-Server/printer/HD/jobs/00000001_couvercle +3.u
    2018-10-25 20:15:28: finish job /var/lib/Repetier-Server/printer/HD/jobs/00000001_couvercle +3.u
    2018-10-25 20:15:29: Updating info for /var/lib/Repetier-Server/printer/HD/jobs/00000001_couvercle +3.g printer HD
    2018-10-25 20:15:34: Starting external command /usr/bin/python with 2 parameters.
    2018-10-25 20:15:34: start printjob couvercle +3 on printer HD
    2018-10-25 20:15:35: LUA job rendering.render#{"id":1,"image":"/var/lib/Repetier-Server/printer/HD/jobs/00000001_couvercle +3_l.png","layer":"/var/lib/Repetier-Server/printer/HD/jobs/00000001_couvercle +3.layer","list":"jobs","slug":"HD"}
    2018-10-25 20:17:16: Reading configuration file ...
    Input file: /var/lib/Repetier-Server/printer/HD/jobs/00000001_couvercle +3.layer
    Rendering shadows ...7.49591 seconds.
    Rendering gcode ...76.8074 seconds.
    Number of end triangles: 174888
    Number of normal triangles: 4682176
    Time for raytracing: 14.5921 seconds.
    images stored.
    Computation time: 101.199 seconds
    2018-10-26 02:14:44: Starting external command /usr/bin/python with 2 parameters.
    2018-10-26 02:21:51: Starting external command /usr/bin/python with 2 parameters.
    2018-10-26 02:21:55: Starting external command /usr/bin/python with 2 parameters.
    2018-10-26 02:21:55: Print of couvercle +3 on printer HD finished. Send 301236 lines. Printing time: 6:06:20
    2018-10-26 02:21:55: Repetier-Informer API response: {"error":0,"data":{"receivers":1}}
    2018-10-26 02:22:02: error: Reading serial conection failed: End of file. Closing connection.
    2018-10-26 02:22:02: Port closed for HD
    2018-10-26 02:22:02: Connection closed: HD
    2018-10-26 08:05:02: Starting external command /usr/bin/python with 2 parameters.
    2018-10-26 08:06:33: Connection started: HD
    2018-10-26 08:06:33: Reset printer HD
    2018-10-26 08:20:55: Job created: /var/lib/Repetier-Server/printer/HD/jobs/00000002_support_aiguille.u
    2018-10-26 08:20:55: finish job /var/lib/Repetier-Server/printer/HD/jobs/00000002_support_aiguille.u
    2018-10-26 08:20:55: Updating info for /var/lib/Repetier-Server/printer/HD/jobs/00000002_support_aiguille.g printer HD
    2018-10-26 08:20:56: Starting external command /usr/bin/python with 2 parameters.
    2018-10-26 08:20:56: start printjob support_aiguille on printer HD
    2018-10-26 08:20:56: LUA job rendering.render#{"id":2,"image":"/var/lib/Repetier-Server/printer/HD/jobs/00000002_support_aiguille_l.png","layer":"/var/lib/Repetier-Server/printer/HD/jobs/00000002_support_aiguille.layer","list":"jobs","slug":"HD"}
    2018-10-26 08:22:08: Reading configuration file ...
    Input file: /var/lib/Repetier-Server/printer/HD/jobs/00000002_support_aiguille.layer
    Rendering shadows ...3.50161 seconds.
    Rendering gcode ...51.6429 seconds.
    Number of end triangles: 36672
    Number of normal triangles: 905560
    Time for raytracing: 14.0504 seconds.
    images stored.
    Computation time: 71.3678 seconds
    the external command is "python set_ifttt.py CMD" (https://github.com/fthome/repetier_ui)
    For the moment my solution is rebooting the raspberry pi every day.
  • Ok, will try the same tomorrow. I would prefer more logging
    ps aux | grep tier
    free is over all programs.
    Can you also try in parallel if this happens if your command is not running. Just to exclude that this is causing the problem. After all I know users running prints much longer without memory issues. So first step should be to find what is triggering the error.
  • I monitor the memory usage with ps aux | grep epetier and note the memory usage of Repetier-server
    pi@Repetier-Server:~ $ ps aux | grep tier
    avahi      317  0.0  0.2   6536  2820 ?        Ss   13:48   0:00 avahi-daemon: running [Repetier-Server.local]
    repetie+   674  3.0  2.7 189844 25776 ?        S<sl 13:48   5:29 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    root       675  0.0  0.2   5064  2828 ?        Ss   13:48   0:00 /bin/bash /home/pi/repetier_ui/repetier_ui.sh
    pi        9438  0.0  0.0   4372   560 pts/0    S+   16:49   0:00 grep --color=auto tier
    repetier_ui is my script.
    abstract :
    from websocket import create_connection
    datas = {'action': 'send', 'data': {'cmd': gcode},'printer':printer}
    try:
        ws = create_connection(self.url, header=self.header)
        ws.send(json.dumps(datas))
    except Exception as e:
        logging.error("WebsocketError: %s"%(err.message))
    finally:
        ws.close
    if repetier_ui is disable, the memory usage is stable
    if repetier_ui is enable, the memory usage increase 4 hours after I use my code
    If websocket is the problem, can you tell me how to use the api to send gcode to the printer.
    the mesures :
    Mémoire repetier server
    29/10/2018 18:00 73160 repetier_ui inactif
    29/10/2018 19:00 73204
    29/10/2018 20:00 73204
    29/10/2018 21:00 73204
    29/10/2018 22:00 73204
    29/10/2018 23:00 73204
    30/10/2018 00:00 73204
    30/10/2018 01:00 73204
    30/10/2018 02:00 73204
    30/10/2018 03:00 73204
    30/10/2018 04:00 73204
    30/10/2018 05:00 73204
    30/10/2018 06:00 73204
    30/10/2018 07:00 73224
    30/10/2018 08:00 73224 Mise en route repetier_ui et utilisation 1 fois : 2018-10-30 08:00:38,538 - INFO - GPIO10 FALLING => GCODE : goto_z_max.gcode send to HD.
    2018-10-30 08:00:47,181 - INFO - GPIO10 FALLING => GCODE : goto_z_max.gcode send to HD.
    30/10/2018 09:00 73252
    30/10/2018 10:00 73252
    30/10/2018 11:00 73252
    30/10/2018 12:00 151584
    30/10/2018 13:00 246436
    30/10/2018 14:00 18092 reboot serveur
    30/10/2018 15:00 22400
    30/10/2018 16:00 24268
  • Ok here my test results in parallel:
    USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
    Start
    repetie+   589  4.7  6.1 193304 27444 ?        S<sl Oct11 1157:29 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    1h Print
    repetie+   589  4.7  6.3 219256 28256 ?        S<sl Oct11 1171:48 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    1h Print
    repetie+   589  4.8  6.8 270456 30444 ?        S<sl Oct11 1184:00 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    5h Print
    repetie+   589  5.0  8.6 278092 38604 ?        S<sl Oct11 1297:45 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
                  total        used        free      shared  buff/cache   available
    Mem:            433         100          30          22         302         260
    Swap:            99           2          97
    8h print
    after 1h
    repetie+   589  5.0  7.6 223820 33744 ?        S<sl Oct11 1321:47 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    pi@Prusa:~ $ free -m
    Mem:            433         102          34          22         296         257
    Swap:            99           2          97
    repetie+   589  5.1  8.3 259820 37256 ?        S<sl Oct11 1339:21 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    repetie+   589  5.1  9.5 225004 42576 ?        S<sl Oct11 1362:09 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    repetie+   589  5.2 10.2 228076 45628 ?        S<sl Oct11 1376:59 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    repetie+   589  5.2 10.2 228076 45628 ?        S<sl Oct11 1380:57 /usr/local/Repetier-Server/bin/RepetierServer -c /usr/local/Repetier-Server/etc/RepetierServer.xml --daemon
    So after 15 hours it increased to 45MB memory usage.
    I could debug my memory increase and it is a result of the lua interpreter having not run garbage collector. Not sure when it would decide to run, so for next release I have now forced a garbage collection after every call. That may take in total more time but each collection is tiny and still quick I guess. Need to do some more tests.
    Communication over websockets might also cause lua calls as that is how normal users could extend the server side to add new functions. But only if the command is not known by the c++ part, so normally not the problem.
    I will try to make a websocket tester that runs many websocket reconnects. Maybe there is a memory issue as well. If I have understoo dthe cod ecorrectly you establish for each test a websocket so a problem there could easily increase faster the memory usage.
    Using it as simple api call would be better here, see
    https://www.repetier-server.com/manuals/programming/API/index.html
    User websocket commands directly
    In the websocket chapter you will see all the small commands you normally use while you are displaying server status. Soem of them might also be useful for simple apps just wanting to show some informations. For these we offer a access over the REST api. The only thing that does not work are events as they are reported to open sockets only.
    http://localhost:3344/printer/api/<slug>?a=<websocket command>&data=<json object properly url-escaped>&apikey=<API key>>
    The above schema can be used to send any websocket command as REST call. Use GET or POST just as you like. For bigger data POSt should be preferred. You can replace apikey with sess, but you would normally do this only if you have no session open, so apikey is the normal way to use it.
    So essentially you the query you send as url encoded data in data and you get the same json response.
  • Ok, I will forget websocket.
    But i do not establish a lot of websocket connections : this morning, I just make two short connections.
    Thanks a lot
  • Can you test with htop - there you see how much threads the server has. It should stay constant if connection is closed.
    Yesterday I trie dusing a browser and reloaded it 50 times without noticeable memory increase. I know it closes connection and leakage tool did not find memory leakage, so in general websockets should not be a problem. But if they keep open it might be a different think.
