LCD Text
Is there a way to change the text sent to the LCD screen IE the "Printing Done" that shows in lower corner of the screen?
If so what file are they all in??
Thank you...
  • You can add messages using M117 but they may get overwritten by status messages or print progress if enabled. So you can only add some but not change existing messages.
    Are they not defined in one of the files loaded into Arduino?
  • Some are, some not. Search for UI_STATUS to see all versions coming from firmware. The rest comes from host.
  • thank you
