interuppted print recovery
Something that happens to all of us is an unexpected print interruption. whether it being computer/program crash, momentary power brown out, etc.
I've encountered this enough to have come up with a rudimentary system of (assuming repetier host is still running, recording down the layer height and taking a picture of where it last was. with that, i go into the g-code, highlight everything that was printed, delete it, and modify the start g-code for what ever the situation is; usually, home x and y, not z (as i will move the x carriage and bed but the z-height wont be touched) set temp and resume. i have done this successfully on a number of occasions but it is very tedious.
However, i believe a little bit of programming can make this much easier.
Basic principle of operation would be that when repetier starts a print, it will make a copy of the g-code (named recovery-temp) and as it sends the g-code to the printer, it will also delete the same g-code from the file. this will create a situation where even if the entire computer crashes or looses power, there will be a record of whats left. and when repetier is restarted (or when an icon within it is pressed) it will initiate recovery mode. it will access "recovery-temp" add the start g-code (this can be standardized but should allow the user to customize it to their needs) and allow them to recover the print.
This can be taken a step further and if repetier is running when the interrupt occurs, it can auto recover; albiet this is much more complicated and i wouldnt focus on this until the base recovery system is implemented.
