Manual control override configuration?
Hi
I'm setting my configuration at the slicer (CureEngine) and then press Slice with CuraEngine and print but even if I set at my config the extruder temp at 230c it stays at 200c as it shown on the manual control.
how can I control my parameters?
  • Make sure to save the new filament settings and also that the setting is selected on the right side. It might be that you modify a different filament then shown to the right and that would still use the old values.
