Problem with LAN static IP
I am trying to get Repetier-server setup on a raspberry pi with a 7in touchscreen. It is wired and connected to a router that does not have a DHCP server. Our IT guy was able to SSH into the raspberry pi and set it while I was away. It works fine until a few seconds after the touchscreen interface finishes loading then loses connection. Could it be possible that repetier-server is changing the ip once it boots?
  • Server it self only manages wifi if not connected. Ethernet is not touched by our software. Normally you would go to /etc/network and edit the eth0 interface to have manual ip and reboot. Then linux will always assign that fixed ip. Not sure how your it guy did it, but that is how I always do it if required.
