invalid extrude ! error for double extruder and low extrusion on sinigle extrude
hello,
please help me out with my flsun printer, the single extruder was working well until few days ago i discover the extrusion was very low, i have checked for clogging and cleared but still experiencing same error. the feeder motor spins very slow. and increase feed rate is not effective, please what can i do
i switched to a dual extruder thereafter and i am getting "invalid extrude 1 error" message please how can i fix.
thanks in anticipation.
When an extruder is not spinning fast enough there are 2 reasons - flow rate reduced also your image has it on 100% or steps per mm for extruder set too low in firmware settings. You often can change steps per mm with the eeprom editor. At least if eeprom was compiled in.
