Clogging normally happens if molten filaments get into higher regions of the extruder, so everything that prevents this helps. - Have a cooler for the higher extruder parts to keep it cool. - Lower temperature so it doe snot creep that high. - Less extruder retraction
The last 2 can be influenced by slicers. Of course if the reason is debris in filament clogging the output nothing will help, except better filament. But I never had such a filament my self, so not that likely then the other reasons.
