Print estimates between host and server vary wildly
Why is it that I slice on repetier host and then send to the server but the print time estimates are wildly off?
My host says 2.5 hours and my server may say 8 hours on the same object when I send it. I just sliced one and it said 20:26:15. I sent it to the printer and it says 35 hours and 51 minutes. Both are wrong to a large degree as one that says 2.5 hours on the host and 8 hours on the server may actually take 5 hours.
I commonly do prints that run 24 hours but when I see 35 hours+ I usually start second guessing whether I actually need it or not.
I also noticed that sometimes I can send a second time and get a much lower number on the exact same object with the exact same slice.
