"Run from here" function
I am a new user of Repetier Host which I like very much. I was surprised when I did not find any "Run from here" function. As a long time Mach3 user I'm used to resume an unfinished print from a particular line. Mach makes a fast background run to your chosen line, then it gives you the ability to set a security z-height in a popup window before continuing. After that, it moves the printhead to that safety z-height and starts printing from the line forward with all commands from the begining of the g-code. This would be a really desirable addition to Repetier which can also be found in people's writings online.
If I stop in Mach the position is automatically set in memory, last line nbr, xpos, ypos, zpos, epos.
In case of run out of filament I make a stop and move the print head with keyboard to the position where it ended. By knowing the exact position it's easy to find the line an continue from here.
When I first encountered this problem in Repetier I started looking for solution how people had solved it. I noticed that there were a lot of people with the same problem. Editing G-Code is Ok but it takes time and is tedious.
The program is excellent. This is the only addition I would like to have so far.
