touchscreen yaxis direction swapped
may be a silly question but I´m Linux noob.
i use a ELO 15" vga touch display (one of these you´ll find in some supermarkets) and y-axis of touchscreen is swapped.
in raspbian i can use xinput_calibrator to swap the axis, also managed to download on the repetier image.
but how can i get to start the calibrator?
Or any other possibility?
(the only one i can imagine is to use the display on raspian , note the settings and transfer manually to the repetier image)
any help is welcome
  • Login using ssh
    export DISPLAY=:0
    xinput_calibrator
    display could also be :1 in some cases. Once you have set the display you can run any command using display from commandline and it will show on the display you have set.
  • Ok,thanks, that moves me one step forward
  • found some time to read and try a couple of things and ended up here:
    but  how can i make that  permanent respectively automatic executed?
    sorry for noob question, I´m still beginner on Linux
  • edited November 2018
    Ok, solved
    for my case (display rotated 270° ) it was just to add
    Option "TransformationMatrix" "1 0 0 0 -1 1 0 0 1"
    in file /usr/share/X11/xorg.conf.d/99-calib.conf
    seems to be different since Server change from debian jessie to stretch
