connection issues
i am currently using a boxzy printer/lazer engraver/mill
Whenever I load up my P.C and load the programs to run my printer, I always have to disconnect the printer and reconnect the printer. Here is the error message i get:
Then shortly after starting a project, ill get something like this come up (the resend line is different each time, even when printing the same thing)(I am currently using the lazer engraver):
any help would be greatly appreciated!
14:32:36.096 : N653 G0 X81.7*65
14:32:36.256 : ok 649
14:32:36.256 : N654 G0 X85.3 F600000*38
14:32:36.366 : ok 650
14:32:36.366 : ok 651
14:32:37.346 : ok 652
14:32:37.346 : N655 M117 ETE 30s*6
14:32:37.346 : N656 M105*34
14:32:37.456 : ok 653
14:32:37.686 : ok 654
14:32:37.686 : N657 L81.2 L100 L100 L100 L100 L100 L100 L100 L100 L100 L100 L57.6 L0 L0 L0 L0 L0 L0*117
14:32:37.786 : ok 655
14:32:38.186 : ok 656
14:32:38.186 : T:989.50 /0 @:0
14:32:38.386 : Resend:657
14:32:38.426 : ok
14:32:38.596 : Resend:657
14:32:38.596 : ok
14:32:38.796 : Resend:657
14:32:38.796 : ok
14:32:38.996 : Resend:657
14:32:38.996 : ok
14:32:39.196 : Resend:657
14:32:39.196 : ok
14:32:39.396 : Resend:657
14:32:39.396 : ok
14:32:39.596 : Resend:657
14:32:39.596 : ok
14:32:39.796 : Resend:657
14:32:39.796 : ok
14:32:39.996 : Resend:657
14:32:39.996 : ok
14:32:40.196 : Resend:657
14:32:40.196 : ok
has many L values. So make sure you have latest host which accepts illegal gcodes and sends them 1:1 maybe that helps here. I guess this is to make the engraver get multiple values faster but it requires that the line is not modified.
Looking at the G-Code, there is a bunch of lines with the same letter repeated, and it does run though alot of them before stopping.
im currently trying to 3D print and keep getting:
10:18:03.654 : Communication timeout - reset send buffer block
every 10-15mins aswell.
