Usage of Project functionality
I see the value of the Project tab in ordering models and adding comments and images. It is way more useful than the 'group' functionality which is present in repetierserver. The latter is useful if you have a limited number of models and subjects, but it is missing multilevel ordering.
I'm a bit surprised that it is not possible to print directly from the project tab. I've added a gcode file, sliced with S3D, to a project, but the only thing you can do is download, copy and delete it. Or am I missing something?
It's nice you can export an entire project, but for me it's not very clear what is the purpose of downloading a project. The .rsproj file apparently is a zip archive, which is very usefull. Can it be used to upload an entire project in e.g. thingiverse or grabcad?
Thanks for the brillant work @repetier-makers!!!
Mike
Mike
it is also meant as one source for models once the slicer is integrated. And you can simply upload zips with stl to make them a project so if you download a thingyverse zip you can just put it there and have the previews, 3d view etc and can even search for text and tags.
