External command not working
Hi All,
I have a script I want to be able to call from the server interface that will backup the servers database/settings. I have the script which is working fine from the command line, but doesn't work when I call it from the web interface.
This is what I have in the extcommands.xml:
<command>
<name>Backup Settings</name>
<execute>sudo /var/lib/Repetier-Server/scripts/backup.sh</execute>
<confirm>Backup settings to home directory? WILL STOP SERVER WHILE BACKING UP!</confirm>
<!-- Define if command should show up in local printer interface, default true.-->
<local>true</local>
<!-- Define if command should show up in remote printer interface, default true.-->
<remote>true</remote>
<!-- Define if command should show up only for users with print permission, default true.-->
<print-permission>false</print-permission>
<!-- Define if command should show up only for users with add files permission, default false.-->
<add-permission>false</add-permission>
<!-- Define if command should show up only for users with del files permission, default false.-->
<del-permission>false</del-permission>
<!-- Define if command should show up only for users with configuration permission, default false.-->
<config-permission>true</config-permission>
</command>
I have even tried <execute>sudo /bin/sh /var/lib/Repetier-Server/scripts/backup.sh</execute> but that didn't work either <name>Backup Settings</name>
<local>true</local>
</command>
