Prusa i3 MK3 heatbed not showing temp
Hello guys. I looked at the forum here about issues with the MK3 heatbed. I know what the issue is by reading through the forum but I did not find any information about how to correct it. The heatbed is just saying undefined.
e.g. M105 21:22:41.637: T:11.63 /0 B:13.18 /0 B@:0 @:0
This is the armel version running on a pcduino2 board. It was working fine until I upgraded to 0.90.1 and I haven't changed firmware or anything. I'm going to downgrade back to 0.90.0 and redefine the heated bed since others are having issues with prints stopping in the middle. I have a 5 hour print I'm about to start.
This is with an I3 variant running Marlin 1.1-bugfix from several months ago.
It so happened this was my first print with Repetier-Server and it failed, not sure why, but that is not the issue here. After I canceled the print, I was able to click "Off" for the hot end and bed. The display on the printer indicated they were cooling down. I clicked the "0" and entered 60 on the bed control. Actually I clicked the left side of the displayed zero and entered "60" which displayed "600", I pressed Del, but the zero on the right would not go away, so I pressed backspace to get rid of the middle zero and hit enter. Bed temp went back to heating and controlled to target. I captured the message for debug:
After this I tried to enter "0" on the heated bed section of the control tab. Heater stayed on. I clicked on the bed icon on the top right and clicked "Off" and the bed turned off and started to cool down. Throughout the whole process, the Heated Bed display nor Heated Bed graph never showed a temperature or a setpoint. At least I had good adhesion.
clayrev
