Problems Setting up Viki 2 on Rambo v1.4
I am having problems installing Viki 2 on my Rambo v1.4 board.
I am confused about the pins on the board.
on DisplayList.h in the repetier firmware these are the pins related to the LCD display:
However there are instructions from this document:
They tell to add the pins in the arduino environment. This confused me.
Also none of the pins match then pins in the Rambo schematic, https://reprap.org/mediawiki/images/7/75/Rambo1-1-schematic.png .
So I do not know how should I connect my Display, I am terribly confused.
#elif MOTHERBOARD == 301 // RAMBO | |
#define SDCARDDETECT 72 // sd card detect as shown on drawing | |
#undef BEEPER_PIN | |
#define BEEPER_PIN 33 | |
// Display A0 | |
#define UI_DISPLAY_D5_PIN 70 | |
// Display CS | |
#define UI_DISPLAY_RS_PIN 71 | |
#define UI_ENCODER_A 85 | |
#define UI_ENCODER_B 84 | |
#define UI_ENCODER_CLICK 83 | |
#define UI_RESET_PIN -1 | |
#define RED_BLUE_STATUS_LEDS | |
#define RED_STATUS_LED 22 | |
#define BLUE_STATUS_LED 32 |
https://reprap.org/mediawiki/images/e/e2/Rambo-LCD.pdf
