XYZ Axis Problem with Fabrikator Mini by TURNIGY
I recently received a Fabrikator Mini 3D printer and I have loved it; however, the last time I used it, the printer's extruder didn't go down far enough to print, thus causing the model to print out as a large plastic ball. I followed the user guide, so this issue doesn't make much sense. Does anybody know what might be causing the issue???
1. End stop doe snow trigger earlier
2. Bed is adjusted deeper some how. Did you remove a plate or put screws tighter?
If you can modify one of these easily you can fix it just by adjusting the height of end stop or bed.
