Repetier Server toggles connection state until ...
Hi all,
Setup:
Atmega 2560 + RAMPS 1.4 with Repetier-Firmware 0.92.9 (configured next to vanilla*) connected via USB to a Linux Mint 18.3 (Sylvia)
RepetierServer 0.86.2 Pro installed on Linux, RepetierHost 2.1.2 is also installed via mono-<whatever> on this box
Arduino IDE: 1.8.5 64bit
The weird behavior I see is that...
RepetierServer won't connect to the Atmega (connection state toggles between "red disconnected symbol" and "orange WiFi icon" UNTIL I fire up RepetierHost, click the connect-button -which connects to the same port as RS, /dev/ttyACM0- and disconnect/close RH; after this RS works until I power down everything / press the reset-button on RAMPS or just disconnect the USB-cable.
*) the single change was that I enabled FEATURE_TWO_ZSTEPPER and selected Extruder1 as mirror stepper socket.
... huh ...
I can't figure out what is going on here.
RH-connection-log shows:
20:30:17.533 : OpenGL version:3.0 Mesa 17.2.8
20:30:17.534 : OpenGL extensions: ---removed by me---
20:30:17.534 : OpenGL renderer:AMD TURKS (DRM 2.50.0 / 4.13.0-43-generic, LLVM 5.0.0)
20:30:17.534 : Using fast VBOs for rendering is possible
20:30:26.429 : No start signal detected - forcing start
20:30:26.442 : N1 M110*34
20:30:26.442 : N2 M115*36
20:30:26.442 : N3 M105*36
20:30:26.442 : N4 M114*35
20:30:26.442 : N5 M111 S6*98
20:30:26.450 : N6 T0*60
20:30:26.450 : N7 M20*22
20:30:26.450 : N8 M80*19
20:30:26.451 : N9 M105*46
20:30:29.531 : N10 M105*22
RS-Log after "Emergency Stop" via Webgui (unsuccessful / connect is flapping)
20:30:25.288: start
20:30:25.288: M110 N0
20:30:25.288: N2 M115
20:30:25.288: N3 M220 S100
20:30:25.288: N4 M221 S100
20:30:25.288: N5 M355
20:30:25.288: N6 G92 E0
20:30:25.288: N7 M114
20:30:25.288: N8 G90
20:30:25.288: N9 M111 S6
20:30:25.288: N10 M360
20:30:25.288: N11 M539 S1
20:30:25.296: Free RAM:5235
20:30:25.296: SelectExtruder:0
20:30:25.300: N12 M117 IP:192.168.42.38
20:30:25.317: FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
20:30:25.321: Printed filament:0.00m Printing time:0 days 0 hours 0 min
20:30:25.321: PrinterMode:FFF
20:30:25.329: Info:No case lights
20:30:25.333: X:0.00 Y:0.00 Z:0.000 E:0.0000
20:30:25.333: DebugLevel:6
20:30:25.337: Config:Baudrate:115200
20:30:25.341: Config:InputBuffer:127
20:30:25.341: Config:NumExtruder:1
20:30:25.345: Config:MixingExtruder:0
20:30:25.345: Config:HeatedBed:0
20:30:25.345: Config:SDCard:0
20:30:25.349: Config:Fan:1
20:30:25.349: Config:Fan2:0
20:30:25.349: Config:LCD:0
20:30:25.353: Config:SoftwarePowerSwitch:1
20:30:25.353: Config:XHomeDir:-1
20:30:25.357: Config:YHomeDir:-1
20:30:25.357: Config:ZHomeDir:-1
20:30:25.362: Config:SupportG10G11:1
20:30:25.362: Config:SupportLocalFilamentchange:1
20:30:25.366: Config:CaseLights:0
20:30:25.366: Config:ZProbe:0
20:30:25.370: Config:Autolevel:0
20:30:25.370: Config:EEPROM:1
20:30:25.370: Config:PrintlineCache:16
20:30:25.374: Config:JerkXY:20.00
20:30:25.374: Config:JerkZ:0.30
20:30:25.378: Config:RetractionLength:3.00
20:30:25.382: Config:RetractionLongLength:13.00
20:30:25.382: Config:RetractionSpeed:40.00
20:30:25.386: Config:RetractionZLift:0.00
20:30:25.390: Config:RetractionUndoExtraLength:0.00
20:30:25.394: Config:RetractionUndoExtraLongLength:0.00
20:30:25.394: Config:RetractionUndoSpeed:20.00
20:30:25.398: Config:XMin:0.00
20:30:25.398: Config:YMin:0.00
20:30:25.398: Config:ZMin:0.00
20:30:25.403: Config:XMax:200.00
20:30:25.403: Config:YMax:200.00
20:30:25.407: Config:ZMax:120.00
20:30:25.407: Config:XSize:200.00
20:30:25.407: Config:YSize:200.00
20:30:25.411: Config:ZSize:120.00
20:30:25.415: Config:XPrintAccel:1000.00
20:30:25.415: Config:YPrintAccel:1000.00
20:30:25.419: Config:ZPrintAccel:100.00
20:30:25.419: Config:XTravelAccel:1000.00
20:30:25.423: Config:YTravelAccel:1000.00
20:30:25.423: Config:ZTravelAccel:100.00
20:30:25.427: Config:PrinterType:Cartesian
20:30:25.431: Config:MaxBedTemp:120
20:30:25.431: Config:Extr.1:Jerk:20.00
20:30:25.435: Config:Extr.1:MaxSpeed:50.00
20:30:25.435: Config:Extr.1:Acceleration:5000.00
20:30:25.439: Config:Extr.1:Diameter:0.00
20:30:25.443: Config:Extr.1:MaxTemp:275
20:30:25.443: Unknown command:N11 M539 S1
20:30:26.472: FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
20:30:26.476: Printed filament:0.00m Printing time:0 days 0 hours 0 min
20:30:26.476: PrinterMode:FFF
20:30:26.480: X:0.00 Y:0.00 Z:0.000 E:0.0000
20:30:26.484: DebugLevel:6
20:30:26.484: SelectExtruder:0
20:30:26.488: Unknown command:N7 M20
20:30:27.311: Error:expected line 10 got 15
20:30:27.315: Resend:10
20:30:27.315: Resend after 160351ms
20:30:27.325: Resend: N10 M360
20:30:27.325: Resend: N11 M539 S1
20:30:27.325: Resend: N12 M117 IP:192.168.42.38
20:30:27.336: Config:Baudrate:115200
20:30:27.336: Config:InputBuffer:127
20:30:27.340: Config:NumExtruder:1
20:30:27.340: Config:MixingExtruder:0
20:30:27.344: Config:HeatedBed:0
20:30:27.344: Config:SDCard:0
20:30:27.344: Config:Fan:1
20:30:27.344: Config:Fan2:0
20:30:27.348: Config:LCD:0
20:30:27.348: Config:SoftwarePowerSwitch:1
20:30:27.352: Config:XHomeDir:-1
20:30:27.352: Config:YHomeDir:-1
20:30:27.356: Config:ZHomeDir:-1
20:30:27.356: Config:SupportG10G11:1
20:30:27.360: Config:SupportLocalFilamentchange:1
20:30:27.360: Config:CaseLights:0
20:30:27.365: Config:ZProbe:0
20:30:27.365: Config:Autolevel:0
20:30:27.365: Config:EEPROM:1
20:30:27.369: Config:PrintlineCache:16
20:30:27.369: Config:JerkXY:20.00
20:30:27.373: Config:JerkZ:0.30
20:30:27.373: Config:RetractionLength:3.00
20:30:27.377: Config:RetractionLongLength:13.00
20:30:27.381: Config:RetractionSpeed:40.00
20:30:27.381: Config:RetractionZLift:0.00
20:30:27.385: Config:RetractionUndoExtraLength:0.00
20:30:27.389: Config:RetractionUndoExtraLongLength:0.00
20:30:27.393: Config:RetractionUndoSpeed:20.00
20:30:27.393: Config:XMin:0.00
20:30:27.397: Config:YMin:0.00
20:30:27.397: Config:ZMin:0.00
20:30:27.397: Config:XMax:200.00
20:30:27.401: Config:YMax:200.00
20:30:27.401: Config:ZMax:120.00
20:30:27.406: Config:XSize:200.00
20:30:27.406: Config:YSize:200.00
20:30:27.406: Config:ZSize:120.00
20:30:27.410: Config:XPrintAccel:1000.00
20:30:27.414: Config:YPrintAccel:1000.00
20:30:27.414: Config:ZPrintAccel:100.00
20:30:27.418: Config:XTravelAccel:1000.00
20:30:27.418: Config:YTravelAccel:1000.00
20:30:27.422: Config:ZTravelAccel:100.00
20:30:27.426: Config:PrinterType:Cartesian
20:30:27.426: Config:MaxBedTemp:120
20:30:27.430: Config:Extr.1:Jerk:20.00
20:30:27.430: Config:Extr.1:MaxSpeed:50.00
20:30:27.434: Config:Extr.1:Acceleration:5000.00
20:30:27.438: Config:Extr.1:Diameter:0.00
20:30:27.438: Config:Extr.1:MaxTemp:275
20:30:27.442: Unknown command:N11 M539 S1
20:30:29.535: skip 10
20:31:09.571: Error:expected line 58 got 11
20:31:09.571: Resend:58
20:31:09.581: M110 N1
20:31:11.570: Error:expected line 4 got 12
20:31:11.570: Resend:4
20:31:11.580: M110 N1
20:31:14.573: Error:expected line 5 got 13
20:31:14.573: Resend:5
20:31:14.583: M110 N1
20:31:17.575: Error:expected line 5 got 14
20:31:17.575: Resend:5
20:31:17.585: M110 N1
20:31:20.573: Error:expected line 5 got 15
20:31:20.577: Resend:5
20:31:20.588: M110 N1
20:31:23.576: Error:expected line 5 got 16
20:31:23.580: Resend:5
20:31:23.590: M110 N1
20:31:26.578: Error:expected line 5 got 17
20:31:26.578: Resend:5
20:31:26.589: M110 N1
20:31:29.581: Error:expected line 5 got 18
20:31:29.581: Resend:5
20:31:29.591: M110 N1
20:31:32.583: Error:expected line 5 got 19
20:31:32.583: Resend:5
20:31:32.593: M110 N1
20:32:02.295: M110 N0
20:32:02.296: N2 M115
20:32:02.296: N3 M220 S100
20:32:02.296: N4 M221 S100
20:32:02.296: N5 M355
20:32:02.296: N6 G92 E0
20:32:02.296: N7 M114
20:32:02.296: N8 G90
20:32:02.296: N9 M111 S6
20:32:02.296: N10 M360
20:32:02.296: N11 M539 S1
20:32:13.316: M110 N0
20:32:13.316: N2 M115
20:32:13.316: N3 M220 S100
20:32:13.316: N4 M221 S100
20:32:13.316: N5 M355
20:32:13.316: N6 G92 E0
20:32:13.316: N7 M114
20:32:13.316: N8 G90
20:32:13.316: N9 M111 S6
20:32:13.316: N10 M360
20:32:13.316: N11 M539 S1
20:32:24.358: M110 N0
20:32:24.358: N2 M115
20:32:24.359: N3 M220 S100
20:32:24.359: N4 M221 S100
20:32:24.359: N5 M355
20:32:24.359: N6 G92 E0
20:32:24.359: N7 M114
20:32:24.359: N8 G90
20:32:24.359: N9 M111 S6
20:32:24.359: N10 M360
20:32:24.359: N11 M539 S1
20:32:35.417: M110 N0
20:32:35.417: N2 M115
20:32:35.417: N3 M220 S100
20:32:35.417: N4 M221 S100
20:32:35.417: N5 M355
20:32:35.417: N6 G92 E0
20:32:35.417: N7 M114
20:32:35.417: N8 G90
20:32:35.417: N9 M111 S6
20:32:35.417: N10 M360
20:32:35.417: N11 M539 S1
20:32:46.448: M110 N0
20:32:46.448: N2 M115
20:32:46.448: N3 M220 S100
20:32:46.448: N4 M221 S100
20:32:46.448: N5 M355
20:32:46.448: N6 G92 E0
20:32:46.448: N7 M114
20:32:46.448: N8 G90
20:32:46.448: N9 M111 S6
20:32:46.448: N10 M360
20:32:46.448: N11 M539 S1
20:32:57.465: M110 N0
20:32:57.465: N2 M115
20:32:57.465: N3 M220 S100
20:32:57.465: N4 M221 S100
20:32:57.465: N5 M355
20:32:57.465: N6 G92 E0
20:32:57.465: N7 M114
20:32:57.465: N8 G90
20:32:57.465: N9 M111 S6
20:32:57.465: N10 M360
20:32:57.465: N11 M539 S1
RS-Log after connectiing via RH and immedialtely disconnecting afterwards:
20:35:54.039: N9 M111 S6
20:35:54.039: N10 M360
20:35:54.039: N11 M539 S1
20:36:03.204: ~ ~ x fxf ff x f ~f ~ f~`fx ~ x ~f f `f ~ Error:Format error
20:36:03.208: Response while unconnected:Resend:1
20:36:03.208: Resend:1
20:36:03.218: Response while unconnected:ok
20:36:03.218: Resend: N2 M115
20:36:03.218: Resend: N3 M220 S100
20:36:03.218: Resend: N4 M221 S100
20:36:03.218: Resend: N5 M355
20:36:03.218: Resend: N6 G92 E0
20:36:03.218: Resend: N7 M114
20:36:03.218: Resend: N8 G90
20:36:03.218: Resend: N9 M111 S6
20:36:03.218: Resend: N10 M360
20:36:03.218: Resend: N11 M539 S1
20:36:04.142: FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mend start
20:36:04.146: Free RAM:5235
20:36:04.150: SelectExtruder:0
20:36:05.112: Error:expected line 1 got 14
20:36:05.309: Resend:1 (2)
20:36:05.346: FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:https://github.com/repetier/Repetier-Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
20:36:05.350: Printed filament:0.00m Printing time:0 days 0 hours 0 min
20:36:05.350: PrinterMode:FFF
20:36:05.354: X:0.00 Y:0.00 Z:0.000 E:0.0000
20:36:05.358: DebugLevel:6
20:36:05.358: SelectExtruder:0
20:36:05.362: Unknown command:N7 M20
20:36:06.116: Error:expected line 10 got 15
20:36:06.116: Resend:10
20:36:06.126: Resend: N10 M360
20:36:06.126: Resend: N11 M539 S1
20:36:06.136: Config:Baudrate:115200
20:36:06.136: Config:InputBuffer:127
20:36:06.141: Config:NumExtruder:1
20:36:06.141: Config:MixingExtruder:0
20:36:06.145: Config:HeatedBed:0
20:36:06.145: Config:SDCard:0
20:36:06.145: Config:Fan:1
20:36:06.145: Config:Fan2:0
20:36:06.149: Config:LCD:0
20:36:06.149: Config:SoftwarePowerSwitch:1
20:36:06.153: Config:XHomeDir:-1
20:36:06.153: Config:YHomeDir:-1
20:36:06.157: Config:ZHomeDir:-1
20:36:06.157: Config:SupportG10G11:1
20:36:06.161: Config:SupportLocalFilamentchange:1
20:36:06.161: Config:CaseLights:0
20:36:06.165: Config:ZProbe:0
20:36:06.165: Config:Autolevel:0
20:36:06.165: Config:EEPROM:1
20:36:06.169: Config:PrintlineCache:16
20:36:06.169: Config:JerkXY:20.00
20:36:06.173: Config:JerkZ:0.30
20:36:06.173: Config:RetractionLength:3.00
20:36:06.177: Config:RetractionLongLength:13.00
20:36:06.182: Config:RetractionSpeed:40.00
20:36:06.182: Config:RetractionZLift:0.00
20:36:06.186: Config:RetractionUndoExtraLength:0.00
20:36:06.190: Config:RetractionUndoExtraLongLength:0.00
20:36:06.194: Config:RetractionUndoSpeed:20.00
20:36:06.194: Config:XMin:0.00
20:36:06.198: Config:YMin:0.00
20:36:06.198: Config:ZMin:0.00
20:36:06.198: Config:XMax:200.00
20:36:06.202: Config:YMax:200.00
20:36:06.202: Config:ZMax:120.00
20:36:06.206: Config:XSize:200.00
20:36:06.206: Config:YSize:200.00
20:36:06.206: Config:ZSize:120.00
20:36:06.210: Config:XPrintAccel:1000.00
20:36:06.214: Config:YPrintAccel:1000.00
20:36:06.214: Config:ZPrintAccel:100.00
20:36:06.218: Config:XTravelAccel:1000.00
20:36:06.218: Config:YTravelAccel:1000.00
20:36:06.222: Config:ZTravelAccel:100.00
20:36:06.227: Config:PrinterType:Cartesian
20:36:06.227: Config:MaxBedTemp:120
20:36:06.231: Config:Extr.1:Jerk:20.00
20:36:06.231: Config:Extr.1:MaxSpeed:50.00
20:36:06.235: Config:Extr.1:Acceleration:5000.00
20:36:06.239: Config:Extr.1:Diameter:0.00
20:36:06.239: Config:Extr.1:MaxTemp:275
20:36:06.243: Unknown command:N11 M539 S1
20:36:17.080: N26 M117 IP:192.168.42.38
Any idea what is going on here?
THX in advance & all the best!
  • Very strange, but log seems incomplete so I can not fully analyse. You need to have all communication including ack marked. I see a N11 command not known so I have to assume firmware got the first 10 successfully. Then
    I see
    So why does firmware expect line 58 after line 11. I do not see that it got send, so resending fails. But this again might have to do with hidden log entries making it impossible to debug. COuld be M105 requests which got hidden. Would also mean communication was good in that example except some unknown commands due to using old firmware. But that is no problem as they simply get ignored.
  • <logfile incomplete>
    oh yes, i know but it ain't easy ...
    Is there a way to configure RS to "please log everything that might be related to communications"?
    > "was good in that example except some unknown commands due to using old firmware."
    at least "old firmware" is not possible, after I ran into the issues mentioned above I swapped out my initial "I don't care if this one lets out the blue smoke" with a known-working 2560+RAMPS1.4, downloaded a vanilla firmware (unmodified except enabling FEATURE_TWO_ZSTEPPER) and flashed my hardware with this build.
    -> same difference; the printer-configuration in RS was also "new" (the first one ever on this box); the printer-setup in RH ditto (I still don't understand why the Arduino-IDE refuses to flash /dev/ttyACM0 while RS is running but RH has no problems connecting to the same port (NO, I did NOT configure RH to connect to RS and YES toggled EEPROM_whatever_ from 1 to 2 and vice versa))
    Next: download a really vanilla/unmodified Firmware-Source from the configurator and flash my kit with this build, who knows what will happen; I've seen stranger issues already ;-)
    Summary: Is there a way to configure RS to "please log everything that might be related to communications"?
    all the best & thx!
  • Followup:
    flashed my kit with a "as it comes"-Firmware-source from https://www.repetier.com/firmware/v092/ via Arduino-IDE
    removed <printer> from RS (RH -> unmodified)
    "add new Printer" in RS, "ok'd everything"
    -> works
    Shutdown printer-hardware + disconnect USB
    powerUp
    RS: working
    *humm*
    service RepetierServer stop
    Switching Sourcecode to "FEATURE_TWO_ZSTEPPER", using Extruder 1; !NOTHING ELSE!
    Download full source, recompile (Upload via Arduino-IDE as before)
    service RepetierServer start
    RS: working.
    Summary: either I'm veering into the "funny as in crazy, not as in laugh"-area or  the firmware-configurator was out of whack the day before yesterday or ... there was something weird going on with <?> and I just should be prevented to faff around with complicated thingamajigs way above my event-horizon.
    *huh*, color me really really confused.
    CLOSED, Cause: UNKNOWN, possibly sunspots.
  • In server frontend in printer context menu is a log page where you can enable logging and also download logs.
    In rare cases you can get multiple reconnects until a printer works. Especially if printers do not reset this can happen if firmware was disconnected in error state(because sending just stopped mit line,...). reconnects happen if we get no answers for a while.
