filament
Hi to all i have install repetier and works fine for few days today all the time is saying to change filament?
pi 3+ im using
  • Check log and printer. It is the printer saying to change filament, becaus ethe filament change sensor triggers and server just reports this. In log you should also see the firmware request.
  • Hi thanks for your respond
    im noob in this when you saying Check log from repeteir - server  in >_Console or there is a G code that i want to send to change the filament sensor ?
    sorry for my bad english
    thanks
  • In console you see communication if you have enabled all (commands, ack).
