Loss of Reset on Connect function in Printer Settings after v1.06
I love your Repetier product and have been using it with the Robox Printer successfully for a while. However, I have to stick at version 1.06 as only this and previous versions have "Reset on Connect" as an option in the printer connection settings. I need to have it set to "DTR low->high->low" for repetier to be able to connect to the Robox.
In all newer versions the "Reset on Connect" function is not available. Is there anyway to include it again in newer versions or another way to force this setting?
Many thnks
Many thnks
When will it be back?
Could you please tell which is the "reset on connect" that the version 2.1.3 does?
When will the option of LHL be back ?
