G-Code Macros?
I am a new user of Server, having used Host for my MPCNC system with great success. I wanted to run it on the Raspberry Pi 7" touch screen and found this software to be the only one that had a solid Local GUI.
I used the Macros quite a bit, for saving fixture start points and such. I have not seen if there are any now in the Server interface, but that would be great to have on the Jog Screen.
  • They are in printer commands, which is only visible if printer is online and you have defined some. You can define them in the server printer configuration and give them names. You can even have more then 5. They also appear in the console in the "Send Predefined" dropdown.
