Unknown printer firmware using Tronxy x5s, Marlin 1.1.7 dev and Host v1.1.0 Mac - serial is ok
I am able to connect using a serial console at 115200 baud and see the dump of parameters from my Tronxy X5S and also AT returns OK, but I still get the unknown printer firmware after connect from Repetier Host for Mac. The log says "Connection opened." Also says 5 commands waiting. I've looked online and everything points to baud rate but I'm sure the baud rate is correct as I said before. Thx for help.
You should also check if you compiled firmware to include line numbers with "ok" so host can detect missed "ok" at a later time fixing the error on the fly instead of blocking for timeout seconds before it continues.
