Thin Wall settings ??
I am trying to get my Slic3r settings to work to print file from 3dlabprint.com. I am told that they use Simplify3d because of several abilities that other slicers do not have.
I am wondering if Slic3r has the ability to print thin walls as well as the ability to print double walls for the first 5 layers (I believe that is what i read).
I tried to slice a part from the file using Slic3r and it came out almost 3 times the weight due to not printing thin walls.
I am not sure if i missed settings or if there is something else going on (I am more inclined to believe I have missed something).
Here is the part that i tried to print (a test part from thingiverse. https
/ www.thingiverse.com/thing:1810679
Any thoughts on this would be most appreciated.
I have an HE3D (with 3 extruders) that i am using. I had to create a new profile that had 1 extrude because I could not import the printing profiles that are included.
Any direction at all here would be most appreciated...
A bit of machine info ... (I currently have 2 printers)
HE3D EI3 (triple extruder)
200x280 build plate
temp 230
retraction dist 6
retraction speed 65
I believe I have an issue with my bowden extruders here (I think the tube bend radius is too narrow, i have more tube coming in and will be rebuilding this printer to re-orient the tubes)
I also have a GeeeTech I3 that has been converted to use a bowden extruder and I am using the same settings.
the build volume is a little smaller with 200x200 build plate
Here is a pic of the HE3D printer (it seems obvious to me now where at least some of my issues lie)
Will test further tomorrow and post results.
