Excessive z axis movement at start.
When I begin a cnc cut with Repetier Server, the z axis moves upward nearly to full length of the axis. It then pauses for about 10 to 15 seconds and comes back down to begin the cut. This does not happen when I make a cut with Repetier Host. I am able to set the safe travel height of 5mm with Host after which the cnc starts the cut. I cannot find which setting in Server I need to make to correct this problem.
