Many problems with the firmware configuration
Hello everyone,
I have built a Vulcanus Max 40 (with 2 extruders) over a year but I can't make it work because I am facing many problems with the firmware configuration. I tryed many firmware versions but I had many problems like compiling errors, no motor moving and more. The only version that kind of works is 0.92. I have done many changes and tests with the configuration etc, to make my machine work. I have reached to a point and I stuck. My main problems are:
1. I home all axis with sequence XYZ to my upper left front corner (I use X min,Y min, Z max). They all home fine. I move axis XY to any direction and move fine, BUT when I press any button from Host, to move the Z axis, either up or down, the bed moves downwards and it stops to my Z max position.
2. If I try to change the #define NUM_EXTRUDER to 2 I get many compiling errors (I attatched the file with the errors).
I would also like to fix the distance between my hotends and the autoleveling bed but I think I have to fix the above first.
Thank you in advance for your help.
Below my configuration.h
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
   as you expect.
#define NUM_EXTRUDER 1
#define MOTHERBOARD 33
#include "pins.h"
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define FAN_THERMO_PIN -1
// Uncomment the following line if you are using arduino compatible firmware made for Arduino version earlier then 1.0
// If it is incompatible you will get compiler errors about write functions not beeing compatible!
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL  -1
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 1
#define XAXIS_STEPS_PER_MM 155
#define YAXIS_STEPS_PER_MM 155
#define ZAXIS_STEPS_PER_MM 420
#define PDM_FOR_EXTRUDER 0
#define PDM_FOR_COOLER 0
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 213
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_HEAT_MANAGER 1
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_PGAIN_OR_DEAD_TIME 45.98
#define EXT0_PID_I 4.76
#define EXT0_PID_D 111.1
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 1
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
#define HEATED_BED_PID_IGAIN   33
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 290
#define MAX_DEFECT_TEMPERATURE 305
// ##                             Laser configuration                                      ##
The default laser driver only supports laser on and off. Here you control the eΓ­ntensity with
automatically disabled.
#define SUPPORT_LASER 0
#define LASER_PIN -1
#define LASER_ON_HIGH 1
// ##                              CNC configuration                                       ##
#define SUPPORT_CNC 0
#define CNC_WAIT_ON_DISABLE 0
#define CNC_ENABLE_PIN -1
#define CNC_ENABLE_WITH 1
#define CNC_DIRECTION_PIN -1
#define CNC_DIRECTION_CW 1
#define ENDSTOP_PULLUP_X_MAX false
#define ENDSTOP_PULLUP_Y_MAX false
#define ENDSTOP_Y_MAX_INVERTING true
#define max_software_endstop_r false
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_Z_BACK_ON_HOME 1
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 0
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 1
#define INVERT_Z_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR 1
#define X_MAX_LENGTH 350
#define Y_MAX_LENGTH 430
#define Z_MAX_LENGTH 350
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ##                           Movement settings                                          ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 20
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 28
#define HOMING_ORDER HOME_ORDER_XYZ
#define ZHOME_HEAT_ALL 1
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 999999
#define ZHOME_Y_POS 999999
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 1
#define DIRECTION_DELAY 2
#define ALLOW_QUADSTEPPING 1
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 100
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 100
#define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 50
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 50
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 50
#define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 40
#define MAX_JERK 20
#define MAX_ZJERK 0.3
#define MOVE_CACHE_LOW 10
#define X2_STEP_PIN   ORIG_E1_STEP_PIN
#define X2_DIR_PIN    ORIG_E1_DIR_PIN
#define Y2_STEP_PIN   ORIG_E1_STEP_PIN
#define Y2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z2_STEP_PIN   ORIG_E1_STEP_PIN
#define Z2_DIR_PIN    ORIG_E1_DIR_PIN
#define Z3_STEP_PIN   ORIG_E2_STEP_PIN
#define Z3_DIR_PIN    ORIG_E2_DIR_PIN
#define USE_ADVANCE 0
#define BAUDRATE 115200
#define POWER_INVERTING 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
#define FEATURE_SERVO 0
#define SERVO0_PIN 11
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define UI_SERVO_CONTROL 0
        #define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 1
#define FEATURE_Z_PROBE 0
#define Z_PROBE_PIN -1
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 0
#define Z_PROBE_X_OFFSET 0
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_REPETITIONS 1
#define Z_PROBE_HEIGHT 4
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 20
#define Z_PROBE_Y1 20
#define Z_PROBE_X2 160
#define Z_PROBE_Y2 20
#define Z_PROBE_X3 100
#define Z_PROBE_Y3 160
#define BED_LEVELING_METHOD 0
#define BED_MOTOR_1_X 0
#define BED_MOTOR_1_Y 0
#define BED_MOTOR_2_X 200
#define BED_MOTOR_2_Y 0
#define BED_MOTOR_3_X 100
#define BED_MOTOR_3_Y 200
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 1
#undef SDCARDDETECT
#define SDCARDDETECT -1
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_CONTROLLER 2
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 1
#define LANGUAGE_NL_ACTIVE 1
#define LANGUAGE_PT_ACTIVE 1
#define LANGUAGE_IT_ACTIVE 1
#define LANGUAGE_ES_ACTIVE 1
#define LANGUAGE_FI_ACTIVE 1
#define LANGUAGE_SE_ACTIVE 1
#define LANGUAGE_FR_ACTIVE 1
#define LANGUAGE_CZ_ACTIVE 1
#define LANGUAGE_PL_ACTIVE 1
#define LANGUAGE_TR_ACTIVE 1
#define UI_PRINTER_NAME "Vulcanus"
#define UI_PRINTER_COMPANY "Johannes Rostek"
#define UI_ANIMATION 0
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 0
#define CASE_LIGHTS_PIN -1
#define UI_SET_PRESET_EXTRUDER_TEMP_PLA   190
#define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
#define UI_SET_MIN_EXTRUDER_TEMP   170
#define UI_SET_MAX_EXTRUDER_TEMP   260
#define NUM_MOTOR_DRIVERS 0
  • edited April 20
    You could try this for your movement issues:
    what does m119 return? should show L when endstop is activated H when not
    #define ENDSTOP_Z_MAX_INVERTING false should be true like the other physical endstops.
    software endstops should be false for the physical (existing) ones and true for the non-existing ones.
    These should be changed if motors move in the wrong direction or you could reverse the plug orientation on the RAMPS board (if possible)
    Hope that might help.
    I don't have dual extruders but I am pretty sure you have to compile it in the firmware. The on-line configurator tool will allow this.
  • Thanks for the eply Roko!
    All of them shows L when they are opened and H when they are triggered.
    I tryed #define ENDSTOP_Z_MAX_INVERTING false, but then when I home Z, bed moves downwards a bit and then stops.
    I also changed the status of the software endstops but nothing changed.
    My motors work fine to every direction. I didn't mention, before home the Z axis, I can move it upwards or downwards normally. I can home all axis and after that if I try to move the Z axis it moves downwards till the farest point (which is Zmax).
    What do you mean to compile it in the firmware? Arduini software does the compliling and uploads it to my board.
    The firmware that I get from the on-line configuration tool also doesn't work.
  • Can you verify,  where is the Z endstop switch located, at the top or the bottom of the machine ?
  • just to be shure i took a look at this:
    http://www.instructables.com/id/Vulcanus-MAX-CoreXY-Aluminum-Frame-RepRap-3D-Print/
    so when your plate moves to bottom of machine at homing homing direction is zmax.
    when it moves close to extruders homing direction is zmin
  • MartinH is located near the extruder. Is a proximity sensor.
    RAyWB yes this is the machine I build a copy of. I am not sure what exactly do you mean. I know that ( in general) the Zmin is the lowest point that a bed can reach and the Zmax the highest right?
    When I turn on the machine and the bed is at any point (let's say in the middle of the printer) I can move it upwards or downwards normally from host. When I press home Z, the bed goes upwards and stops near the extruders (when the Z endstop triggers) as it should. NOW my problem starts. If now I try to move downwards the bed, it starts moving downwards and doesn't stop. It stops after 350mm which is the Z max length I have set for my printer.
  • edited April 21
    youre wrong.  Zaxis  distance is measured from extruders to bed.
    so when bed is on biggest distance to extruders its ZMAX and when it´s closest distance to extruders its ZMIN.
    when you do your homing the way you wrote it´s zmin homing.
    so it seems your defines of zaxis direction ,Zendstop and homing direction is wrong.
    you have to set
    #define ENDSTOP_PULLUP_Z_MAX false
    #define Z_HOME_DIR -1
    not shure about
    #define INVERT_Z_DIR 0   ,
    if you move z+ direction and it moves away from extruders its ok,otherwise set
    #define INVERT_Z_DIR 1
  • I did what you told me and  also connected the proximity sensor to Zmin pin on the raps 1.4 board.
    Now I can move the bed normally, with z+ goes upwards and with z- goes downwards.
    But when I home Z it moves a little bit upwards and stops which it means the machine understands the bed has reached the home position right? I trigger the sensor with a metal and press the Zhome button and the bed goes downwards and when I release the sensor the bed stops. In this case the bed is trying to home away from the extruders.
  • Sorry I forgot to mention I fixed the sensor triggering by changing #define MIN_HARDWARE_ENDSTOP_Z from true to false and again when I home Z my bed goes downwards.
  • I fixed that! I didn't read carefully the part you said :
    "if you move z+ direction and it moves away from extruders its ok,otherwise set
    Sorry about that.
    Now it homes fine but when I press Z+ from host my bed moves downwards and when I press Z- my bed goes upwards. Is this normal? it is going to print normally?
    Thank you anyway for your help.
    About the two extruders configuration and the compiling problem has anyone any idea?
  • edited April 21
    yes, that´s exactly what it should do !
    if you move z + , the distance from bedto extruder has to get bigger
    regarding 2nd extruder , it´s not enough to change the number from 1 to 2.
    think it´s best to use the configtool with corrected settings
  • RAyWB you are the best!!!! Your tips were really helpful!
    I tryed again the configuration tool (by the way it is very helpful) and I put the settings that I have tested so far. The only problem I have now is with my  second extruder heater. To heat it up from Host, I need to turn on the second extruder icon and also the fan. I think this has something to do with the pins configuration right? I am trying right now to fix this.
  • edited April 21
    on Ramps it is not possible to have heated bed, 2 extruders and fan as you just have 3 mosfet outputs...
    there are some extension boards available to add more mosfet outputs.
  • Yes I know. I have connected the fan directly on 12VDC for now and later I will fix that. I also saw that there are some extention boards for extra fans. I have connected my 2nd extruder to D9 instead of fan. How can I make this D9 output to control 2nd extruder?
  • edited April 21
    seems you have activated fan and second extruder  in config tool.
    disable fan in config tool or
    add following lines to configuration.h
    after line :
    #include "pins.h"
    add :
    #undef FAN_PIN
    #define FAN_PIN           4
  • Yes that worked for me thank you.
    After a long day with configurating, testing etc I have everything almost done, except autoleveling bed.
    I followed the instructions of z probing, although some points werent perfectly clear for me, and I sent a G30! I got the following error:
    "Error:z-probe triggered before strarting probing."
    I use z prob and z min endstop from the same pin and their status operates normally when I trigger it.
    I looked around  in forum but didn't find any topic about this.
    Below my latest configuration file if you can see something wrong
       as you expect.
    #define NUM_EXTRUDER 2
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN -1
    #define BOARD_FAN_SPEED 255
    #define EXT0_STEPS_PER_MM 120
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT1_X_OFFSET 8812
    #define EXT1_Y_OFFSET 0
    #define EXT1_Z_OFFSET 0
    #define EXT1_STEPS_PER_MM 107
    #define EXT1_TEMPSENSOR_TYPE 1
    #define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
    #define EXT1_HEATER_PIN HEATER_2_PIN
    #define EXT1_STEP_PIN ORIG_E1_STEP_PIN
    #define EXT1_DIR_PIN ORIG_E1_DIR_PIN
    #define EXT1_INVERSE 0
    #define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
    #define EXT1_ENABLE_ON 0
    #define EXT1_MIRROR_STEPPER 0
    #define EXT1_INVERSE2 0
    #define EXT1_MAX_FEEDRATE 50
    #define EXT1_HEAT_MANAGER 3
    #define EXT1_WATCHPERIOD 1
    #define EXT1_PID_I 2
    #define EXT1_PID_D 40
    #define EXT1_PID_MAX 255
    #define EXT1_ADVANCE_K 0
    #define EXT1_ADVANCE_L 0
    #define EXT1_JAM_PIN -1
    #define EXT1_JAM_PULLUP 0
    #define HEATED_BED_MAX_TEMP 68
    #define MAXTEMP 275
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define Y_MAX_LENGTH 450
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_CORRECTION_POINTS 3
    #define DISTORTION_XMIN 0
    #define DISTORTION_YMIN 0
    #define DISTORTION_XMAX 334
    #define DISTORTION_YMAX 432
    // Delta settings
    #define MAX_FEEDRATE_Z 140
    #define HOMING_FEEDRATE_Z 14
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 500
    #define MAX_JERK 14
    #define DUAL_X_AXIS 0
    #undef PS_ON_PIN
    #define FEATURE_Z_PROBE true
    #define Z_PROBE_BED_DISTANCE 3.32
    #define Z_PROBE_PULLUP true
    #define Z_PROBE_ON_HIGH true
    #define Z_PROBE_X_OFFSET 42
    #define Z_PROBE_Y_OFFSET 54
    #define Z_PROBE_WAIT_BEFORE_TEST false
    #define Z_PROBE_SWITCHING_DISTANCE 5
    #define Z_PROBE_REPETITIONS 4
    #define Z_PROBE_HEIGHT 1.6
    #define Z_PROBE_START_SCRIPT "Auto leveling bed started.."
    #define Z_PROBE_FINISHED_SCRIPT "Auto leveling bed completed!"
    #define Z_PROBE_X1 0
    #define Z_PROBE_Y1 0
    #define Z_PROBE_X2 334
    #define Z_PROBE_Y2 0
    #define Z_PROBE_X3 0
    #define Z_PROBE_Y3 432
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "3DP"
    #define UI_PRINTER_COMPANY "Laspiros"
    #define UI_ANIMATION 1
    #define UI_AUTORETURN_TO_MENU_AFTER 8000
    #define FEATURE_BEEPER 1
    #define UI_SET_PRESET_HEATED_BED_TEMP_PLA 55
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   200
        "editMode": 0,
        "processor": 0,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 155,
        "yStepsPerMM": 155,
        "zStepsPerMM": 420,
        "xInvert": "1",
        "xInvertEnable": 0,
        "eepromMode": 1,
        "yInvert": "1",
        "yInvertEnable": 0,
        "zInvert": "1",
        "zInvertEnable": 0,
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 45.98,
                "pidI": 4.76,
                "pidD": 111.1,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 213,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "id": 1,
                "heatManager": 3,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 1,
                "sensorPin": "TEMP_2_PIN",
                "heaterPin": "HEATER_2_PIN",
                "maxFeedrate": 50,
                "invert": "0",
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetract": 0,
                "stepsPerMM": 370,
                "coolerPin": -1,
                "coolerSpeed": 255,
                "xOffset": 56.85,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 8812,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 1",
                    "step": "ORIG_E1_STEP_PIN",
                    "dir": "ORIG_E1_DIR_PIN",
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 1,
        "yMinEndstop": 1,
        "zMinEndstop": 2,
        "xMaxEndstop": 0,
        "yMaxEndstop": 0,
        "zMaxEndstop": 0,
        "motherboard": 33,
        "driveSystem": 1,
        "xMaxSpeed": 200,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 50,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 200,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 50,
        "yPrintAcceleration": 1000,
        "zMaxSpeed": 120,
        "zHomingSpeed": 14,
        "zTravelAcceleration": 40,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 350,
        "yLength": 450,
        "zLength": 350,
        "alwaysCheckEndstops": "1",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 1,
        "directionDelay": 2,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 14,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "1",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 160,
        "homeOrder": "HOME_ORDER_XYZ",
        "featureController": 2,
        "uiPrinterName": "3DP",
        "uiPrinterCompany": "Laspiros",
        "uiPagesDuration": 4000,
        "uiAnimation": "1",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 8000,
        "featureKeys": "0",
        "uiEncoderSpeed": 1,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "1",
        "uiPresetBedTempPLA": 55,
        "uiPresetBedABS": 110,
        "uiPresetExtruderPLA": 200,
        "uiPresetExtruderABS": 240,
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 68,
        "bedSensorType": 1,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeatManager": 1,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": -1,
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbePin": "ORIG_Z_MIN_PIN",
        "zProbeBedDistance": 10,
        "zProbePullup": "1",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 0,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 2.5,
        "zProbeStartScript": "Auto leveling bed started..",
        "zProbeFinishedScript": "Auto leveling bed completed!",
        "featureAutolevel": "1",
        "zProbeX1": 0,
        "zProbeY1": 0,
        "zProbeX2": 334,
        "zProbeY2": 0,
        "zProbeX3": 0,
        "zProbeY3": 432,
        "zProbeSwitchingDistance": 1,
        "zProbeRepetitions": 1,
        "sdSupport": "1",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 3,
        "yEndstopRetestFactor": 3,
        "zEndstopRetestFactor": 3,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": "ORIG_Z_MAX_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": "ORIG_PS_ON_PIN",
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionPoints": 3,
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 0,
        "distortionXMax": 334,
        "distortionYMin": 0,
        "distortionYMax": 432,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "1",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1
        "manualConfig": "",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "defaultPrinterMode": 0,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 0,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 5,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 2,
        "version": 92.9,
        "primaryPortName": ""
  • edited April 23
    Might be this setting :
    as endstop is still triggered after homing try to set it to 1
    for a simple test send g1 Z10 before the autolevel command
    BTW:
    change to actual firmware as there are many improvements especially on autolevel
  • Yup! once again that worked! Really thank you!
    Do you mean to update to firmware 1.0 right?
    I suppose I can upload my fixed configuration file and update it to the newest right?
  • exactly
  • Hi again,
    So I have updated my firmware to the latest one, I have set z probing and everything works smoothly. I also print some objects very good.
    At this point I have a strange communication problem and I don't know if I should start a new topic about this or I should continue here. I also looked around in forum for similar problem but I didn'r found something.
    The problem is this. I print something only with the extruder 1 and everything is OK. I print something only with the extruder 2 and everything is fine. BUT when I try to print a combined object with both extruders I have continuously this:
    14:30:20.170 : Resend:16
    14:30:20.195 : Error:Wrong checksum
    14:30:20.195 : Resend:16
    14:30:23.213 : Warning: Seems like we missed a ok, got a wait - continue sending.
    14:30:23.222 : Error:expected line 16 got 18
    14:30:23.222 : Resend:16
    14:30:23.246 : Error:Wrong checksum
    14:30:23.246 : Resend:16
    14:30:26.265 : Warning: Seems like we missed a ok, got a wait - continue sending.
    14:30:26.274 : Error:expected line 16 got 18
    14:30:26.274 : Resend:16
    14:30:26.298 : Error:Wrong checksum
    14:30:26.298 : Resend:16
    14:30:29.313 : Warning: Seems like we missed a ok, got a wait - continue sending.
    14:30:29.321 : Error:expected line 16 got 18
    14:30:29.321 : Resend:16
    14:30:29.346 : Error:Wrong checksum
    14:30:29.346 : Resend:16
    Although, Host has enabled the bed heating, the temperature of the bed doesn't rise and I have continuously this error.
    I also tryed another cable but nothing changed.
  • edited April 24
    regarding heatbed :
    did you power up both 12V Inputs on Ramps Board?   (the one marked 11A is for Heatbed)
    regarding command:
    What´s sent in Line 16 ( the one which causes Checksum error)
    (you have to enable commands in log to see)
  • I'm not sure which inputs do you mean for heatbed.
    Heatbed is working normal. It reaches my set tempersture (54oC).
    How do I find line 16?
    The last lines of log here:
    15:39:12.433 : Resend: N28 G90*42
    15:39:12.442 : Error:expected line 16 got 18
    15:39:12.442 : Resend:16
    15:39:12.454 : Resend: N16 M531 Dual_Extruder_Calibration_Printc55beef74c122c69c80c3bef6b349fd6-Calibration_Target_A_v1-1 +1*1
    15:39:12.454 : Resend: N17 M117 ETE 12m 11s*123
    15:39:12.471 : Error:Wrong checksum
    15:39:12.471 : Resend:16
    15:39:15.489 : Warning: Seems like we missed a ok, got a wait - continue sending.
    15:39:15.489 : Resend: N18 M532 X0.0 L0*20
    15:39:15.489 : Resend: N19 M107*29
    15:39:15.489 : Resend: N20 M190 S57*104
    15:39:15.489 : Resend: N21 M104 T0 S200*16
    15:39:15.489 : Resend: N22 M104 T1 S200*18
    15:39:15.489 : Resend: N23 G28*34
    15:39:15.489 : Resend: N24 G1 Z5 F5000*50
    15:39:15.489 : Resend: N25 M109 T0 S200*25
    15:39:15.489 : Resend: N26 M109 T1 S200*27
    15:39:15.489 : Resend: N27 G21*47
    15:39:15.489 : Resend: N28 G90*42
    15:39:15.497 : Error:expected line 16 got 18
    15:39:15.497 : Resend:16
    15:39:15.510 : Resend: N16 M531 Dual_Extruder_Calibration_Printc55beef74c122c69c80c3bef6b349fd6-Calibration_Target_A_v1-1 +1*1
    15:39:15.510 : Resend: N17 M117 ETE 12m 11s*123
    15:39:15.523 : Error:Wrong checksum
    15:39:15.526 : Resend:16
    15:39:18.545 : Warning: Seems like we missed a ok, got a wait - continue sending.
    15:39:18.546 : Resend: N18 M532 X0.0 L0*20
    15:39:18.546 : Resend: N19 M107*29
    15:39:18.546 : Resend: N20 M190 S57*104
    15:39:18.546 : Resend: N21 M104 T0 S200*16
    15:39:18.546 : Resend: N22 M104 T1 S200*18
    15:39:18.546 : Resend: N23 G28*34
    15:39:18.546 : Resend: N24 G1 Z5 F5000*50
    15:39:18.546 : Resend: N25 M109 T0 S200*25
    15:39:18.546 : Resend: N26 M109 T1 S200*27
    15:39:18.546 : Resend: N27 G21*47
    15:39:18.546 : Resend: N28 G90*42
    15:39:18.554 : Error:expected line 16 got 18
    15:39:18.554 : Resend:16
    15:39:18.566 : Resend: N16 M531 Dual_Extruder_Calibration_Printc55beef74c122c69c80c3bef6b349fd6-Calibration_Target_A_v1-1 +1*1
    15:39:18.566 : Resend: N17 M117 ETE 12m 11s*123
    15:39:18.579 : Error:Wrong checksum
    15:39:18.579 : Resend:16
  • edited April 24
    seems that the filename is causing the Problem:
    can you rename the file ?
    or give more Information what slicer / host Software you are using incl. your setup
  • Yes after I rename the files it worked fine. I think the file names were too long.
