Unhandled Exception error
Hi guys. I have only just started using Repetier and I keep getting an error splashscreen everytime I open the program. Although when I pless continue it loads up and seems to work normally and I have not run into any problems as yet, it is a bit annoying. The error I am getting is:
Unhandled exception has occured in a component in your application......
Object reference not set to an instance of an object.
Any help will be greatly appreciated. I have searched through the forums but didn't come across anything. If I missed something I appologize.
The log details are as follows:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at RepetierHost.Main.LoadGCodeOrSTL(String file)
at RepetierHost.Main.timer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2633.0 built by: NET471REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
RepetierHost
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Repetier-Host/RepetierHost.exe
Win32 Version: 4.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
RepetierHostExtender
CodeBase: file:///C:/Program%20Files/Repetier-Host/RepetierHostExtender.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.7.2612.0 built by: NET471REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
OpenTK
Assembly Version: 1.2.0.0
Win32 Version: 1.2.2336.6514-pre
CodeBase: file:///C:/Program%20Files/Repetier-Host/OpenTK.DLL
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
ColorSlider
CodeBase: file:///C:/Program%20Files/Repetier-Host/ColorSlider.DLL
CuraEngine
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/CuraEngine/CuraEngine.dll
RepetierServerConnector
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/RepetierServerConnector/RepetierServerConnector.dll
RRFirmwares
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/RRFirmwares/RRFirmwares.dll
SlicerSlic3r
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3r/SlicerSlic3r.dll
SlicerSlic3rPE
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3rPE/SlicerSlic3rPE.dll
System.ServiceProcess
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
Newtonsoft.Json
Assembly Version: 6.0.0.0
Win32 Version: 6.0.8.18111
CodeBase: file:///C:/Program%20Files/Repetier-Host/Newtonsoft.Json.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mscorlib
RepetierHost
System
System.Drawing
System.Core
System.Xml
OpenTK
Accessibility
ColorSlider
CuraEngine
RRFirmwares
SlicerSlic3r
SlicerSlic3rPE
Newtonsoft.Json
enabled.
For example:
<configuration>
</configuration>
