cannot add the slic3r engine with RH1.0.6 under LinuxMint
Hi all !
I install tne latest version of RepetierHost : version 1.0.6, on my LinuxMintDebianEdition 64bit.
Everything goes well with the CuraEngine, which is bundled with RH.
But
I cannot install the Slic3r engine, even if I am connected as Root (not only "sudo" or "su", I also tried to sign in as Root) : the Add button remain gray in all configuration so I cannot add any other engine than Cura.
Am I the only one ?
  • [SOLVED]
    Just type in something in the "name" area at the bottom of the window, dummy reader !!
