Can't go below Z0 even with end stops disabled - How to calibrate then?
Hello. my procedure for setting my z probe offset involves disabling software end stops with M211 S0, sneaking up on the position that I want, setting the offset and finally re-enabling the end stops. Well, Repetier doesn't seem to let me do that. Even with the end stops disabled, it will not let me sneak past the Z home position. I have to use another app. Am I missing something? Thank you.
By hand you can still send
G1 Z-1
to go to negative positions.
Going below 0 is normally an error and normally only happens when your printer is not configured correctly. Z=0 should be the bed and there is no need to go lower.
For bed leveling you should have a metal block with known height and probe against this. This is more precise then paper method and has always z>0.
IR: - Can be unprecise if lights change or reflections on bed are not constant. Overall works good, but - has offsets.
Force Feedback: +No offset, -might bend bed until it triggers, * Needs to find the very small negative z probe height required to trigger.
For FF we also have bending correction if bed is that weak or you need forces that really bend bed. Not sure how piezos work, never used them. Guess they just have a short spike where you see the signal.
To find z probe height you can always test distance where it triggers and measure real distance with gauge or however you like. The difference is the error of z probe height you have to add/subtract to current value.
