Repetier Server Image file V7 doesn't work with Raspberry Pi 3+ (2018) ??
Hi All,
Tried use image from website (RepetierS-V7) and after card insert, red LED is blinking on new Raspberry Pi 3+ (2018).
Do you've any new release of full image?
Also, tried build RepetierS from begin - working fine with Raspbian (2018-03). Only few features missing - but I thing need spend more time on configuration (e.g. missing WiFi files - /usr/local/Repetier-Setup/bin/manageWifiAccess or Shutdown/Reboot menu feature even after update by CL).
Cheers,
Adam
Cheers,
Adam
A new image will come with next server release (0.90) which will also use the new debian release. So for the moment it might in deed be required to use the original pi image and install server package directly.
Making the image is not that easy because we add quite some extra features and optimizations into it to keep image small and make adding webcams, wifi, screensaver as easy as possible. So I think best is to wait for me to finish the image. Hope to have it running in a few days.
big thanks for your work
