Incomplete UI Bug
Greetings, I'm having problems with my Repetier Server installation, when I try to turn on my raspberry pi, this is the first thing that appears and I can't print or modify my printer settings.
Thank you in advance for your help.
  • That interface is only for quick tasks at the printer. The configuration is done in the normal web frontend. So connect to one of the ip's you see in network and do the configuration there. There you can also upload gcodes. At the pi you could do this with an usb stick and import function if configured to do so. usb stick should have vfat32 format.
