Flow rate setup is working ?
Hi all, i find a strange problem on my anycubic delta plus... maybe i have issue from long time dont know...  well i setup a material with 105% of estrusion.... made slice with cura engine and all go ok then print from usb but... ... on display i have a 100%FR  and also in manual control of RH the slicer is set to 100%....
also tried to change to 105% from display or from repetier host slicer but no change on display.... so ... i'm printing with which FR ??
G
M
T
Rileva linguaAfrikaansAlbaneseAraboArmenoAzeroBascoBengaleseBielorussoBirmanoBosniacoBulgaroCatalanoCebuanoCecoChichewaCinese (semp)Cinese (trad)CoreanoCreolo HaitianoCroatoDaneseEbraicoEsperantoEstoneFilippinoFinlandeseFranceseGalizianoGalleseGeorgianoGiapponeseGiavaneseGrecoGujaratiHausaHindiHmongIgboIndonesianoIngleseIrlandeseIslandeseItalianoKannadaKazakoKhmerLaoLatinoLettoneLituanoMacedoneMalabareseMalagasyMaleseMalteseMaoriMaratiMongoloNepaleseNorvegeseOlandesePersianoPolaccoPortoghesePunjabiRumenoRussoSerboSesothoSingaleseSlovaccoSlovenoSomaloSpagnoloSundaneseSvedeseSwahiliTagikoTailandeseTamilTedescoTeluguTurcoUcrainoUnghereseUrduUsbecoVietnamitaYiddishYorubaZulu
La funzione vocale è limitata a 200 caratteri
  • They get multiplied. Slicers include the multiplication already in their E values, so you normally print in host/server with 100%. This is a additional factor that can be used to change ratio after slicing if you see you get not enough/too much filament.
  • edited March 2018
    G
    M
    T
  • edited March 2018
    Thanks... so the material setting FR is working, and the panel and/or slicer work on top of it... so if i put 200% in material value work and i get double material but i see 100% on panel because it referreal to my "startup value" (200%) ?
    G
    M
    T
  • Exactly.
