G92 does nothing
My settings for X,Y,Z were to 0 (I understand that I need to adjust z manually with the endstop) at the end stop so I set them to X: 94 Y: 30 z: 0.40 Here they are perfectly centered on my printer, so I type in G92 X0 Y0 Z0. I've tried sending it multiple times, reconnecting with the printer, and even restarted the printer, but the code doesn't effect anything. It still say X: 94 Y: 30 Z: 0.40 what am I doing wrong?
If you are for example in repetier-host it will show real coordinates including offsets.
Here you can send
@isathome
if the current position should be 0,0,0
In general you should not need to use G92 if firmware and printer are configured well. I guess you tweak Z instead of adjusting the z endstop here.
