Web socket notifications node.js
Hello , thank you for the super work thats been done here !!
A quick question , Im getting the printer info from the Web Socket via node.js and its working quite well. The only thing that I can not figure is if the server is sending a notification of when a print is done. I know you can get the progress via the "listPrinter" command but does the server also send a "Print Done" via web socket similar to the LCD message.
Best regards
Paul
Best regards
Paul
jobFinished (0.60.2)
Payload: {start:unixTime,duration:seconds,end:unixTime,lines:linesOfJob}Gets send after a normal job has finished.
jobKilled (0.60.2)
Payload: {start:unixTime,duration:seconds,end:unixTime,lines:linesOfJob}Gets send after a normal job has been killed.
jobStarted (0.60.2)
Payload: {start:unixTime}Gets send after a normal job has been started.
