Installation on Debian
about one month ago I bought a 3D printer. For this printer the manufacturer included the SW Repetier Host Version 1.6.2.
I am using Linux on Debian environment.
The installation on Debian 7 (Linux Kernel 3.2) did not work. More in details, I could install the program w/o problem but the SW was not able to start correctly, no GUI, no feedback. nothing.
Instead of checking the reason of this problem I decided to install the new version of Debian, that is Debian 9 (LInux Kernel 4.9)
The question:
Before I repeat the installation with the new Debian SW I would like to know if I have to install anyway the Repetier Host Version 1.6.2 or the new one Version 2.05 is also possible.
Another question.
For the next version of Debian (sid, still unstable) is a version of Repetier Host already available.
Does it seem reasonable to try to install this SW for an unstable version of Debian also on the actual version I am using?
Many thanks in advance for a feedback
best regards
Federico
The question:
Another question.
best regards
Federico
many thanks for the feedback.
At coming weekend I will try to install the 2.0.5 version.
I will keep you informed, I think this info could be useful also for other users...
Bye
Federico
yesterday I tried to install the program repetierHost 2.0.5.
Unfortunately there is some kind of problem.
Just attached the report after executing the script configureFirst.sh (I removed some text in german or translated from german to english...)
$ sh configureFirst.sh
System: i686
Using 32 bit CuraEngine
[sudo] Passwort für XXXXX:
Paket libmono-winforms2.0-cil not available, referenced from other program
Nevertheless the following paket
mono-reference-assemblies-2.0 mono-devel
substitutes libmono-winforms2.0-cil
E: for paket »libmono-winforms2.0-cil« there is no candidate for the installation.
rm: '/usr/bin/repetierHost' cannot be removed; file or directory not found
Checking if you are in the dialout group.
0
Adding user mctl03 to the dialout group.
You need to login again in order to connect to your printer.
Compiling helper software to allow non ansi baud rates for some boards
depending on the used serial driver.
configureFirst.sh: 52: configureFirst.sh: g++: not found
Configuration finished.
IMPORTANT: In addition to the bundled CuraEngine, the host also
supports Slic3r, Slic3r Prusa Edition and Skeinforge. These slicers are not bundled, so
need to install them according to their docs and then set the path
to them in Repetier-Host.
For Slic3r simply unpack the tar you get on http://slic3r.org in this directory.
For Slic3r Prusa Edition check https://github.com/prusa3d/Slic3r/releases
The host will then register and add it automatically on next restart.
IMPORTANT: You need a recent mono version since the host uses .NET 4.0
If you see the following error message, your mono is too old!
>>> System.Windows.Forms.SplitContainer doesn't implement interface System.ComponentModel.ISupportInitialize <<<
This folder now contains a repetier-RepetierHost.desktop file
Copy it to your desktop to get a launch icon there
If I try to run repetierHost from the terminal an error message is generated, that is "mono" is missing, the program cannot be executed
Another problem: there is no icon of the program available or that can be seen
Do you have any idea what is the solution?
Many thanks in advance for the feedback
BR
Federico
sudo apt-get install build-essential mono-complete libmono-winforms2.0-cil monodevelop libmono-system-serviceprocess4.0-cil
I think the last one might be missing.
Then it tries to compile a file but you have no g++ compiler installed. No big deal if the precompiled version works under your linux. And it seems to be newer so it should find required libraries.
Icon description is created as repetier-RepetierHost.desktop file.
It gets installed with
sudo desktop-file-install --rebuild-mime-info-cache repetier-RepetierHost.desktop
but if your desktop/linux requires different solution it will not appear. All the many linux versions are hard to handle, that is why we prefer the AppImage that is much more independent and also makes icons on first start.
sorry for late feedback, but I am ill at them moment.
I have checked all of available libmono packages (around 62) under Debian, below reported:
Package libmono-2.0-1
stretch (stable) (cli-mono): Mono JIT library (Default version)
4.6.2.7+dfsg-1: amd64 arm64 armel armhf i386 mipsel ppc64el s390x
Package libmono-2.0-dev
stretch (stable) (cli-mono): Mono JIT library - Development files (Default version)
Package libmono-accessibility4.0-cil
stretch (stable) (cli-mono): Mono Accessibility library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-addins-cil-dev
stretch (stable) (cli-mono): addin framework for extensible CLI applications/libraries
1.0+git20130406.adcd75b-4: all
Package libmono-addins-gui-cil-dev
stretch (stable) (cli-mono): GTK# frontend library for Mono.Addins
Package libmono-addins-gui0.2-cil
Package libmono-addins-msbuild-cil-dev
stretch (stable) (cli-mono): MSBuild task library for Mono.Addins
Package libmono-addins-msbuild0.2-cil
Package libmono-addins0.2-cil
Package libmono-cairo4.0-cil
stretch (stable) (cli-mono): Mono Cairo library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-cecil-cil
stretch (stable) (cli-mono): library to generate and inspect CIL assemblies
0.9.5+dfsg-5: all
Package libmono-cecil-cil-dev
0.9.5+dfsg-5: all
Package libmono-cecil-flowanalysis-cil
stretch (stable) (cli-mono): FlowAnalysis extension for Mono.Cecil
0.1~vcs20110809.r1.b34edf6-3: all
Package libmono-cecil-flowanalysis-cil-dev
Package libmono-cecil-private-cil
stretch (stable) (cli-mono): Mono.Cecil library
4.6.2.7+dfsg-1: all
Package libmono-cecil-vb0.9-cil
stretch (stable) (cli-mono): Visual Basic 2012 Cecil libraries for Mono
4.0.1-1: all
Package libmono-cil-dev
stretch (stable) (cli-mono): Mono Base Class Libraries (BCL) - Development files
4.6.2.7+dfsg-1: all
Package libmono-codecontracts4.0-cil
stretch (stable) (cli-mono): Mono.CodeContracts library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-compilerservices-symbolwriter4.0-cil
stretch (stable) (cli-mono): Mono.CompilerServices.SymbolWriter library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-corlib4.5-cil
stretch (stable) (cli-mono): Mono core library (for CLI 4.5)
4.6.2.7+dfsg-1: all
Package libmono-cscompmgd0.0-cil
stretch (stable) (cli-mono): Mono cscompmgd library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-csharp4.0c-cil
stretch (stable) (cli-mono): Mono.CSharp library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-custommarshalers4.0-cil
stretch (stable) (cli-mono): Mono CustomMarshalers library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-data-tds4.0-cil
stretch (stable) (cli-mono): Mono Data Library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-db2-1.0-cil
stretch (stable) (cli-mono): Mono DB2 library
4.6.2.7+dfsg-1: all
Package libmono-debugger-libs-cil-dev
stretch (stable) (cli-mono): Mono soft debugger interface libraries - development headers
0+20131201.3459502-1: all
Package libmono-debugger-soft-cil
stretch (stable) (cli-mono): Mono soft debugger interface libraries - low level API
Package libmono-debugger-soft4.0a-cil
stretch (stable) (cli-mono): Mono Soft Debugger library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-debugging-cil
stretch (stable) (cli-mono): Mono soft debugger interface libraries - API abstraction
Package libmono-debugging-soft-cil
stretch (stable) (cli-mono): Mono soft debugger interface libraries - Mono.Debugging backend
Package libmono-fuse-cil
stretch (stable) (cli-mono): CLI binding for FUSE
0.4.2+dfsg-4: amd64 arm64 armel armhf i386 mipsel ppc64el s390x
Package libmono-http4.0-cil
stretch (stable) (cli-mono): Mono.Http library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-i18n-cjk4.0-cil
stretch (stable) (cli-mono): Mono I18N.CJK library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-i18n-mideast4.0-cil
stretch (stable) (cli-mono): Mono I18N.MidEast library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-i18n-other4.0-cil
stretch (stable) (cli-mono): Mono I18N.Other library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-i18n-rare4.0-cil
stretch (stable) (cli-mono): Mono I18N.Rare library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-i18n-west4.0-cil
stretch (stable) (cli-mono): Mono I18N.West library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-i18n4.0-all
stretch (stable) (cli-mono): Mono I18N libraries metapackage (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-i18n4.0-cil
stretch (stable) (cli-mono): Mono I18N base library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-ldap4.0-cil
stretch (stable) (cli-mono): Mono LDAP library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-management4.0-cil
stretch (stable) (cli-mono): Mono Management library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-messaging-rabbitmq4.0-cil
stretch (stable) (cli-mono): Mono Messaging RabbitMQ library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-messaging4.0-cil
stretch (stable) (cli-mono): Mono Messaging library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-microsoft-build-engine4.0-cil
stretch (stable) (cli-mono): Mono Microsoft.Build.Engine library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-microsoft-build-framework4.0-cil
stretch (stable) (cli-mono): Mono Microsoft.Build.Framework library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-microsoft-build-tasks-v4.0-4.0-cil
stretch (stable) (cli-mono): Mono Microsoft.Build.Tasks.v4.0 library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-microsoft-build-utilities-v4.0-4.0-cil
stretch (stable) (cli-mono): Mono Microsoft.Build.Utilities.v4.0 library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-microsoft-build4.0-cil
stretch (stable) (cli-mono): Mono Microsoft.Build library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-microsoft-csharp4.0-cil
stretch (stable) (cli-mono): Mono Microsoft.CSharp library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-microsoft-visualbasic10.0-cil
stretch (stable) (cli-mono): Visual Basic 2012 runtime libraries for Mono
4.0.1-1: all
Package libmono-microsoft-visualc10.0-cil
stretch (stable) (cli-mono): Mono Microsoft.VisualC library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-microsoft-web-infrastructure1.0-cil
stretch (stable) (cli-mono): Mono Microsoft.Web.Infrastructure library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-oracle4.0-cil
stretch (stable) (cli-mono): Mono Oracle library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-parallel4.0-cil
stretch (stable) (cli-mono): Mono.Parallel library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-peapi4.0a-cil
stretch (stable) (cli-mono): Mono PEAPI library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-posix4.0-cil
stretch (stable) (cli-mono): Mono.Posix library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-profiler
stretch (stable) (cli-mono): Mono profiler libraries
Package libmono-profiler-gui-thread-check
stretch (stable) (cli-mono): Mono profiler library to debug GUI threading issues
2.99.3-2+b2: s390x
2.99.3-2+b1: amd64 arm64 armel armhf i386 mipsel ppc64el
Package libmono-rabbitmq4.0-cil
stretch (stable) (cli-mono): Mono RabbitMQ.Client library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Package libmono-reflection-cil
stretch (stable) (cli-mono): CLI reflection helper library
1.0+git20110407+d2343843-3: all
Package libmono-reflection-cil-dev
Package libmono-relaxng4.0-cil
stretch (stable) (cli-mono): Mono Relaxng library (for CLI 4.0)
4.6.2.7+dfsg-1: all
Could you maybe suggest me the right packages to be installed?
BR
Federico
is what I normally install and worked so far.
i have just checked your list again, i.e.
build-essential
mono-complete
monodevelop
All of the packages are available except the libmono-winforms2.0-cil.
Suggested is to substitute this package with mono-reference-assemblies-2.0. This package is related to .NET 2.0.
There is also another possibility, i.e. mono-reference-assemblies-4.0 related to .NET 4.0
What is the right one, version for .NET 2.0 or 4.0?
Thank for feedback
BR
Federico
finally I was able to run the program :-)
For you and other people interested in installing this program on Debian 9 (stretch), the following packages must be installed:
- build-essential
- mono-complete
- monodevelop
- mono-reference-assemblies-4.0 (to substitute libmono-winforms2.0-cil)
Other packages needed for the program repetierHost, i.e. mono-devel (to substitute libmono-winforms2.0-cil) and libmono-system-serviceprocess4.0-cil are already included in mono-complete.
Then I run the batch createDesktopIcon.sh and now it is also possible to have the icon available for starting the program by icon.
Just a final point. If I start the program from the terminal the following messages appears:
Gtk-Message: Failed to load module "canberra-gtk-module"
libpng warning: iCCP: known incorrect sRGB profile
Do you have any idea about the reason fo this message? What do I have to do in this case?
Of course I have to check all of the functionalities of this program, but at least the program runs...
Best regaads
Federico
The sRGB profile is just a warning so worst that can happen is wrong gamma correction. I have seen this also in my case.
No idea where this comes from. Host is a windows software so does not use gtk at all. Of course mono uses gtk as window platform, so it will be part of the mono winform implementation. But seems not important if you did not see an error so far. Guess that would show quickly if we needed to use the parts of the library.
I appear to be running mono version 5.14.0.177
When I try to install mono-reference-assemblies-4.0, apt-get removes mono-complete and mono-devel, so I continue to get errors when I start RepetierHost. The initial window frames appear and some of the assets display ok, but there is alot left blank and then it crashes back to terminal.
Any idea why I can't have all of these installed at the same time? Should I be using a specific version of mono? How would I install it?
Hi, thanks for the reply.
Most of the errors seemed to be loading Windows.Forms.* components, but the warning about libmono-winforms2.0.cil turned out to be a red herring which distracted me from realising the underlying issue...
This is the process I followed that helped me determine the issue:
unpack in /opt using sudo account
run configureFirst.sh from the unpacked folder as sudo
run createDesktopIcon.sh as local user
The last stage generated a permissions error when trying to chmod the desktop file before copying it. I ran again as sudo, but then went to change permissions of the ~/Desktop copy manually, which made me look at the permissions for all the files.
I figured the exe files and possibly the dlls needed to be marked as executable for mono, so I set all files to 777 and then everything loaded properly.
I'm not sure which files need which exact permissions at this stage, I may investigate further what the minimum safest settings are, but I suggest some additions to the configure script to at least allow the executables to execute.
It's not difficult.
Maybe it will help someone.
