Print starting immediately after 'Run job' selected
Hi all,
My printer is starting immediately without waiting for the bed and extruder to warm up. i have set a temperature in the filament configuration and do not know what I am missing.
Log just says cold extrusion prevented over and over.
What settings am I missing?
Thanks in advance.
  • Your slicer start code should contain
    M109
    and
    M190
    to wait for target temperature. If you use CuraEngine you need to create a start gcode. Use the button to generate a default version for a quick start. SLic3r normally adds it if you do not override it with own start gcode containing temperature commands.
