first start notification says the print will end at the time it started
I just started a print at 6:18:05 PM. At 6:18:06 PM I get a notification "print for printer default started. The print will finish around 6:18:06 PM. Unless I have one of those new supersonic 3D printers that just isn't right. Any idea how I can rectify this aside from just disabling the print start notification?
Android S8+ running Android 7.0 and Repetier-Informer v. 1.0.0
Thanks much,.
Dave
Thanks much,.
Dave
I cannot edit this any longer but these are from the host. The server does the same thing but just in GMT instead. I need to see if I can find a way to have it show current system time zone rather than GMT (I hate math) <span>
Dave
Do you print directly or do you upload a model and then select it for printing? Maybe that is the difference and message gets send before time computation is finished. WOudl at least explain the error and why it does not happen to me as I always first upload to models and then print the model so computation is already done before starting the print.
Dave
Dave
The timezone is the timezone of the computer the server runs on. If you use our pi image that would be GMT. YOu need to change the timezone to change the format. Just login with ssh and run
sudo raspi-config
In localisation menu you can set the timezone.Dave
