CR-10 Not Printing
Repetier indicates connected with printer. After slicing and pressing print, nothing happens - no heat, no fan, no action. Is there a setting I missed? Should the printer controller be off or on?
  • Check in log if you get any responses from your firmware. E.g. an answer on M114, M115 or M119. If not you most probably have used a wrong baud rate.
  • Error message = "OpenGL"
    What does that mean?
  • OpenGL is the 3d driver for the 3d view. Do you see it? That should have nothing to do with firmware connection.
