TCP IP mkssbase
Hi
We are running repetier server on windows 8. We would like to 3D print over TCP IP using a crossover Ethernet cable connected between the pc and the mks sbase board V1.3 (smoothieware). Our machine is a heated chamber machine so all the eletronics are isolated including sensors. After going through the docs we understand that if we print via USB and a pi we would require the USB length as short as possible. This is what we can do but all the external motor drivers and motors are installed in the same section plus the ac wiring for the heaters which would cause noise. Please provide a solution in this case.
