Fabricator v2 mini manual control issues
Hi new to 3d printing and bought a fab v2 mini. Gone through set up after a few issues with drivers and now arrived at setting up xyz axis. Put all settings in several time but it nothing moves on the printer - just shows command waiting message. Put the sd card in to see if printer was working and everything seems fine just can’t home the axis. Does anyone have any advice please.
  • Use correct baud rate and port should do the trick. x commands waiting means it used a serial port but does not understand what printer says, which happens with wrong baud rate. Could also be a incompatible firmware, not sure what your printer is running. Host only supports reprap compatible firmwares.
