Problem w/ RaspberryPi Zero and RepetierServer
I recently bought a Tevo Tarantula, which I have been successfully print with using Repetier-Host. However since there is no room for the printer in my office I have moved it to another room and have been trying to setup Repetier-Server on a RaspberryPi Zero w/ Repetier-Server to control the printer from my office. I have everything setup, and it appears to be correct. I can successfully connect to the Repetier-Server, and have setup the printer and the server appears to be connecting to the printer. But, no commands to the printer respond. I cannot home or move the motors, and printing does not work. I am kind of stumped here. It appears the connection between Repetier-Host in my office and the Repetier-Server on the RaspberryPi are communicating successfully, however the Repetier-Server seems to not be able to communicate over serial to the printer correctly. All the settings are the same for the serial connection as when I was just using the Repetier-Host on my main PC. Anyone have any idea what could be going on?
sudo adduser repetierserver dialout
seems like that command does not always succeed on install but is required to connect.
no luck with that.
/dev/ttyAMA0 doesnt seem to work, but I connect on /dev/ttyUSB0. There is also a /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AL03P0Y1-if00-port0.
