Print stopping weirdness
Quick question... I have Duplicator i3 and been having success on shorter prints using the Rasberry Pi Server image on a Pi 3. However, I keep discovering stopped prints maybe 2 hours into an 8 hour job... I thought I'd try printing the same code from the built-in SD card to eliminate Repetier Server from the equation and that also failed, however, I hadn't disconnected the USB cable to the PI. The same model is now going great guns on just SD card with no USB connected. Of course, coincidence can play a part - but could Repetier still have had a bearing whilst being connected (but not used)? Apologies for the long drawn out explanation... Thanks!
In such cases you should enable logging and check what is in the log when such a hang happens. Also test if it still happens with dry run being enabled (M111 S14). Often it is power fluctation on printer side that causes the usb connection to drop/hang. Also check /var/log/syslog around the hang time on the pi.
So now looking back at the PI - think I made a schoolboy error powering Logitech webcam directly from the PI. So introducing a powered USB hub and trying again. The PI logs were full of comms errors and the mac mini had none so I'm guessing I was overloading the power on the PI and causing it a headache... I'll check back in once I've done some more experiments!
