Bug slicing with curengine
Everything was working well but yesterday without no reason Cura engine decided to bug when slicing whaever might be the sliced object.
See print screen below
I tryed to reinstall repetier but it had no effect.
I saw some data stayed on the software after uninstall / install like start gcode, end gcode,...
I think I might have to clean those data staying on the computer and after reinstall repetier but I don't know where I can find it.
Am I true?
Where can I find it?
see below the content of "details"
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: startIndex
at System.String.IndexOf(Char value, Int32 startIndex, Int32 count)
at CuraEngine.CuraEngineInstance.ParseGCode(String orig, List`1 flist, Int32 bedTemp, CuraPrintSettings printSettings)
at CuraEngine.CuraEngineInstance.WriteCuraConfig(String filename)
at CuraEngine.CuraEngineInstance.Slice(String[] files, String output)
at RepetierHost.view.SlicerPanel.StartSlicing()
at RepetierHost.view.SlicerPanel.buttonStartSlicing_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2116.0 built by: NET47REL1LAST
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
RepetierHost
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Repetier-Host/RepetierHost.exe
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
RepetierHostExtender
CodeBase: file:///C:/Program%20Files/Repetier-Host/RepetierHostExtender.DLL
System.Configuration
Win32 Version: 4.7.2053.0 built by: NET47REL1
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
OpenTK
Assembly Version: 1.2.0.0
Win32 Version: 1.2.2336.6514-pre
CodeBase: file:///C:/Program%20Files/Repetier-Host/OpenTK.DLL
Accessibility
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
ColorSlider
CodeBase: file:///C:/Program%20Files/Repetier-Host/ColorSlider.DLL
CuraEngine
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/CuraEngine/CuraEngine.dll
RepetierServerConnector
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/RepetierServerConnector/RepetierServerConnector.dll
RRFirmwares
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/RRFirmwares/RRFirmwares.dll
SlicerSlic3r
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3r/SlicerSlic3r.dll
SlicerSlic3rPE
CodeBase: file:///C:/Program%20Files/Repetier-Host/plugins/SlicerSlic3rPE/SlicerSlic3rPE.dll
System.ServiceProcess
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
Newtonsoft.Json
Assembly Version: 6.0.0.0
Win32 Version: 6.0.8.18111
CodeBase: file:///C:/Program%20Files/Repetier-Host/Newtonsoft.Json.DLL
OpenTK.GLControl
CodeBase: file:///C:/Program%20Files/Repetier-Host/OpenTK.GLControl.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Am I true?
mscorlib
RepetierHost
System
System.Drawing
System.Core
System.Xml
OpenTK
Accessibility
ColorSlider
CuraEngine
RRFirmwares
SlicerSlic3r
SlicerSlic3rPE
Newtonsoft.Json
OpenTK.GLControl
enabled.
For example:
<configuration>
</configuration>
I had a "{" on a line with no other symbol. So as usual in computer science the mistake was in between the screen and the chair.
Thanks for your help.
