REpetier / Geeetech i3 Pro C start printing setting
What setting should I do to start printing at the center of the plate?
Com is set now, printing starts to the side.
Thank you
  • Prints appear at coordinates where it got sliced. You see it in the gcode. So if teh object wa splaced in middle and appears after slicing on the side then you should check the coordinates for bed and size in host and slicer used.
  • bed cradles are correct, I use another 3d printing program, with that I do not create problems, the print runs correctly in the center using the same identical g-code. Perhaps there are other repetier parameters that need to be modified.
