I need to access the dot-folders and files
I asked this earlier and was shown a way around the issue, but, that is no longer valid as it generates two sets of Parameter files.
I start Repetier.appimage and select "slic3r Prusa Edition" as the slicer and then make changes to one of the Slic3rPE configurations and save it as "PLA-205-0-25%" I can use it every time I run Repetier. All good.
But, if I run Slic3r-PE.appimage on it's own and make changes to the config-files, it saves them to it's own .slic3r (dot) folder off the User-Folder.
I now have two different version of the Slic3rPE configurations and I cannot point Repetier Slicer-Configuration at a 'dot' Folder or File.
Is there some way I can get the Slic3r Files all in the one Folder but still visible to BOTH Repetier and SlicerPE appimages?
