Suicide dive when extruding fast (for changing filament)
Using a Pi 3 in combination with Repetier server 0.86.2, a Kossel delta printer with Radds microcontroller.
I've noticed some strange behaviour. When I press extrude fast 100, the printer makes a suicide dive, it tries to push the nozzle into the bed. This happens when I use the server to extrude, but also when I use the filament change option. With distances lower then 100, it does not happen.
When using repetier host, connected to the server, everything works perfectly. Does anyone have ideas?
EDIT: It is basically the same error as dot_bob
I think I figured it out. In Repetier host I've set my home position to be x:0 Y:0 Z:394,10.
I've since set it on the server, and now it works
