Repetier host stops working after some test movements
I am working with Repetier Host 1.0.6 in Windows 8 in a delta printer.
The Arduino Mega I was using recently stopped working and I had to change it. I forgot to save the eeprom settings so I lost them.
While I was trying to make some tests to reset the values RepetierHost stopped working. I could make some movements before the printer stopped responding. Then several commands were queued and if I manually send a code (to check endstops status for example) it gets queued. At some point, some seconds after that, if I try to send another command or make any movement the program stops responding and eventually gets closed. This situations gets repeated every time.
Did anyone got the same problem? Have you found a solution?
Thanks in advance
