Unable to Connect: Maker Select Plus / Windows 10
Hi All,
I've exhausted the help that google can provide and need some personalized assistance
Printer: Monoprice Maker Select Plus
OS: Windows 10
Error: Unable to connect to the printer on Com4 (this is the right com port)
I have not yet been able to connect my monoprice maker select plus to repetier host. Here's what I've done:
What can I do?
Best,
Rob
OS: Windows 10
- Ensure that only HOST is running and that SERVER is stopped
- Ensured that CURA is not connecting to my printer
- Plugged printer in with USB - under print settings I see com4 appear and disappear when the printer is plugged/unplugged
- Set baud rate to 115200 (have also tried stock baud rate - but the internet says this is the rate for my printer)
- When I click "apply" my printer does reboot
- Click "Connect" - get error
What can I do?
Best,
Rob
has printer connected to any other s/w?
You could also connect with a normal serial terminal and send M115 to see if and what it responds. If you see garbage the baud rate is wrong.
