Unable to Connect: MP Maker Select Plus / Windows 10
Hi All,
I've exhausted the help that google can provide and need some personalized assistance <span>
</span>
Printer: Monoprice Maker Select Plus
OS: Windows 10
Error: Unable to connect to the printer on Com4 (this is the right com port)
I have not yet been able to connect my monoprice maker select plus to repetier host. Here's what I've done:
What can I do?
Best,
Rob
OS: Windows 10
- Ensure that only HOST is running and that SERVER is stopped
- Ensured that CURA is not connecting to my printer
- Plugged printer in with USB - under print settings I see com4 appear and disappear when the printer is plugged/unplugged
- Set baud rate to 115200 (have also tried stock baud rate - but the internet says this is the rate for my printer)
- When I click "apply" my printer does reboot
- Click "Connect" - get error
What can I do?
Best,
Rob
What is always a try is 250000 baud. It's also often used and maybe printer is just configured to that baud rate. If you use server make also sure to select correct firmware. Repetier-Firmware is not understood by Marlin.
