cannot reach 0.127.0.0.1
got this message "cannot reach 0.127.0.0.1" permission denied on my raspberry.
after searching a lot , i found that SD Card was full (<24MB space available)
i took that Card to a Ubuntu Computer and deleted some Folders containing timelapse Images,
after that Server was running again as expected.
QUESTION :
is there a possibility to prevent from filling SD-Card by timelapse to a defined value, what means to stop
recording when Limit is reached?
in my case issue is solved, that´s just a question ( may be i overlooked a Setting)
ok, happened on 14h print with high Picture rate, just wanted to let you know.
replaced the 16GB Card by a 32GB now so i´m more on the safe side
so the folder was if i remember correct > 9GB.
print finished correct , but no way to reboot the next day.
so i think i have some bigger prints within the next 2 weeks. i´ll enable log and see if i can reproduce the error.
Yes, just wanted to see if i can get something close to realtime Video , i know tht´s unusal.
so for future i´ll do the realtime stuff on the Computer Standing beside my Printer.
but thanks for investigate :-)
