Issues with repetier - Error: [steps]
Hi there,
I have some issues with my new corexy printer. Software 0.92.9. Testing X and Y axes, Z axis isn't plugged in yet.
Endstop state after M119 executing:
endstops hit: x_min:L x_max:L y_min:L y_max:L z_min:H z_max:H Z-probe state:H
The problem is I can't print... I start my "dry" print - hotend temp is set to 150C. Printer is homing and then goes to the centre of table. It starts printing but few seconds later I see:
23:44:15.746 : Error: [steps]
23:44:15.746 : Resend:122
23:44:15.766 : Error: [steps]
23:44:15.767 : Resend:122
23:44:18.806 : Warning: Seems like we missed a ok, got a wait - continue sending.
23:44:18.813 : Error:expected line 122 got 128
23:44:18.815 : Resend:122
23:44:18.833 : Error: [steps]
full log with ACK turned on looks like:
18:51:51.637 : busy:heating
18:51:51.715 : T:154.15 /150 B:25.35 /0 B@:0 @:0
18:51:52.723 : T:153.58 /150 B:25.35 /0 B@:0 @:4
18:51:53.651 : busy:heating
18:51:53.731 : T:152.95 /150 B:25.35 /0 B@:0 @:34
18:51:54.739 : T:152.44 /150 B:25.35 /0 B@:0 @:46
18:51:55.666 : busy:heating
18:51:55.748 : T:151.88 /150 B:25.35 /0 B@:0 @:60
18:51:56.756 : T:151.31 /150 B:25.35 /0 B@:0 @:74
18:51:57.679 : busy:heating
18:51:57.765 : T:150.85 /150 B:25.23 /0 B@:0 @:69
18:51:58.371 : ok 40
18:51:58.371 : ok 41
18:51:58.371 : N50 M105*18
18:51:58.371 : ok 42
18:51:58.371 : ok 43
18:51:58.371 : N51 M117 ETE 52m 43s*122
18:51:58.374 : ok 44
18:51:58.374 : ok 45
18:51:58.374 : Printing layer 1 of 224
18:51:58.374 : ok 46
18:51:58.374 : ok 47
18:51:58.374 : N52 G1 X101.19 Y93.325 E3.62755 F1800*60
18:51:58.374 : N53 G1 X102.632 Y93.093 E3.72512*96
18:51:58.374 : N54 G1 X107.368 Y93.093 E4.04148*101
18:51:58.378 : ok 48
18:51:58.383 : T:150.51 /150 B:25.35 /0 B@:0 @:78
18:51:58.383 : ok 49
18:51:58.383 : ok 50
18:51:58.383 : N55 G1 X109.236 Y93.489 E4.16903*107
18:51:58.384 : T:150.51 /150 B:25.35 /0 B@:0 @:78
18:51:58.386 : Error: [steps]
18:51:58.387 : Resend:51
18:51:58.400 : ok
18:51:58.400 : Resend: N51 M117 ETE 52m 43s*122
18:51:58.400 : Resend: N52 G1 X101.19 Y93.325 E3.62755 F1800*60
18:51:58.400 : Resend: N53 G1 X102.632 Y93.093 E3.72512*96
18:51:58.400 : Resend: N54 G1 X107.368 Y93.093 E4.04148*101
18:51:58.400 : Resend: N55 G1 X109.236 Y93.489 E4.16903*107
18:51:58.405 : Error: [steps]
18:51:58.405 : Resend:51
The second problem is when I disable Z-max endstop by #define MAX_HARDWARE_ENDSTOP_Z false. EXT0 temp is -900C and of course I can't heat extruder...
Could you please assist?
Thanks,
Paweu
18:51:58.400 : ok
Thanks,
Paweu
makes no sense as well as your second problem that disabling endstop changes temperature.
How big is your data section? It must be smaller then 60KB or you will get very strange errors, so maybe this is a result from it. Happens normally if you have lcd with too many languages selected.
My third problem is I can't run 12864 LCD. I can select things in menu but the main screen is corrupted:
http://imgur.com/1kTs0GH
So I disabled it.
#define FEATURE_CONTROLLER 0
It didn't help... I decreased speed to 25% and was able to print ~1min:
19:13:14.964 : T:150.68 /150 B:26.05 /0 B@:0 @:43
19:13:14.964 : ok 206
19:13:14.964 : N213 G1 X106.141 Y111.119 E12.78647*80
19:13:15.147 : ok 207
19:13:15.148 : N214 G1 X105.625 Y111.119 E12.82311*82
19:13:16.294 : ok 208
19:13:16.294 : N215 G1 X105.625 Y98.881 E13.69162*105
19:13:16.297 : T:150.68 /150 B:26.05 /0 B@:0 @:43
19:13:16.297 : ok 209
19:13:16.297 : N216 G1 X105.109 Y98.881 E13.72826*96
19:13:16.481 : ok 210
19:13:16.481 : N217 G1 X105.109 Y111.119 E14.59677*93
19:13:18.495 : busy:processing
19:13:19.459 : ok 211
19:13:19.459 : N218 M105*44
19:13:19.459 : ok 212
19:13:19.462 : T:150.68 /150 B:26.05 /0 B@:0 @:43
19:13:19.462 : ok 213
19:13:19.462 : N219 M117 ETE 3h 29m 32s*53
19:13:19.483 : ok 214
19:13:19.483 : N220 G1 X104.593 Y111.119 E14.63341*86
19:13:19.583 : ok 215
19:13:19.583 : N221 G1 X104.593 Y98.881 E15.50192*98
19:13:20.409 : ok 216
19:13:20.409 : N222 G1 X104.278 Y99.016 F7200*119
19:13:20.510 : ok 217
19:13:20.510 : N223 G1 X102.175 Y99.016 E15.6175 F3000*50
19:13:21.653 : ok 218
19:13:21.657 : T:150.68 /150 B:25.93 /0 B@:0 @:43
19:13:21.657 : Error:2]
19:13:21.658 : Resend:219
19:13:21.659 : N224 M105*35
19:13:21.671 : ok
19:13:21.671 : Resend: N219 M117 ETE 3h 29m 32s*53
19:13:21.671 : Resend: N220 G1 X104.593 Y111.119 E14.63341*86
19:13:21.671 : Resend: N221 G1 X104.593 Y98.881 E15.50192*98
19:13:21.671 : Resend: N222 G1 X104.278 Y99.016 F7200*119
19:13:21.671 : Resend: N223 G1 X102.175 Y99.016 E15.6175 F3000*50
19:13:21.671 : Resend: N224 M105*35
19:13:21.677 : Error:2]
19:13:21.677 : Resend:219
19:13:21.691 : ok
19:13:22.700 : wait
19:13:23.709 : wait
19:13:24.716 : wait
19:13:24.716 : Warning: Seems like we missed a ok, got a wait - continue sending.
19:13:24.716 : N225 M117 ETE 3h 29m 31s*57
19:13:24.716 : N226 M105*33
19:13:24.717 : N227 G1 X102.175 Y99.477 E15.6428*93
19:13:24.717 : N228 G1 X104.278 Y99.477 E15.75838*99
19:13:24.717 : N229 G1 X104.278 Y99.937 E15.78368*104
19:13:24.717 : N230 G1 X102.175 Y99.937 E15.89926*102
19:13:24.717 : N231 G1 X102.175 Y100.397 E15.92456*86
19:13:24.723 : Error:expected line 219 got 225
19:13:24.725 : Resend:219
19:13:24.739 : ok
19:13:24.739 : Resend: N219 M117 ETE 3h 29m 32s*53
19:13:24.739 : Resend: N220 G1 X104.593 Y111.119 E14.63341*86
19:13:24.739 : Resend: N221 G1 X104.593 Y98.881 E15.50192*98
19:13:24.739 : Resend: N222 G1 X104.278 Y99.016 F7200*119
19:13:24.739 : Resend: N223 G1 X102.175 Y99.016 E15.6175 F3000*50
19:13:24.739 : Resend: N224 M105*35
19:13:24.745 : Error:2]
19:13:24.746 : Resend:219
P.S. how to check the data section?
The LCD problem points eventually to same problem. The bars show that it is configured correct only strings are missing which can come from the data size as well.
What is more important I can print with 300% speed without any error messages!
Thanks Repetier team
Maybe it i related to "lag detection" feature?
Could you try upgrading to dev version as I know that it does not have this message.
The result:
11:27:44.356 : Error:Wrong checksum
11:27:44.356 : Resend:1667
11:27:44.403 : ok
11:27:44.403 : Resend: N1667 G1 X96.16 Y104.73 E68.1039*104
11:27:44.403 : Resend: N1668 G1 X96.132 Y105.024 E68.11331*89
11:27:44.403 : Resend: N1669 G1 X96.433 Y105.341 F7200*75
11:27:44.403 : Resend: N1670 M532 X0 L2*1
11:27:44.403 : Resend: N1671 G1 E64.61331 F2400*6
11:27:44.403 : Resend: N1672 G92 E0*117
11:27:44.403 : Resend: N1673 G1 X78.685 Y110.173 F7200*72
11:27:44.403 : ok 1667
11:27:44.403 : N1674 M532 X2,9 L2*18
11:27:44.403 : ok 1668
11:27:44.419 : ok 1669
11:27:44.419 : N1675 M532 X2,9 L2*19
11:27:44.419 : N1676 G1 E3.5 F2400*51
11:27:44.434 : ok 1670
11:27:44.434 : ok 1671
11:27:44.434 : ok 1672
11:27:44.434 : N1677 G1 X78.677 Y99.836 E3.82843 F3000*50
11:27:44.434 : N1678 G1 X131.323 Y99.835 E5.50101*101
11:27:44.434 : Error:Wrong checksum
11:27:44.434 : Resend:1673
11:27:44.481 : ok
11:27:44.481 : Resend: N1673 G1 X78.685 Y110.173 F7200*72
11:27:44.481 : Resend: N1674 M532 X2,9 L2*18
11:27:44.481 : Resend: N1675 M532 X2,9 L2*19
11:27:44.481 : Resend: N1676 G1 E3.5 F2400*51
11:27:44.481 : Resend: N1677 G1 X78.677 Y99.836 E3.82843 F3000*50
11:27:44.481 : Resend: N1678 G1 X131.323 Y99.835 E5.50101*101
11:27:44.481 : ok 1673
11:27:44.481 : N1679 M532 X2,9 L2*31
11:27:44.481 : ok 1674
11:27:44.481 : ok 1675
11:27:44.481 : ok 1676
11:27:44.481 : N1680 G1 X131.323 Y110.164 E5.8292*107
11:27:44.481 : N1681 G1 X78.745 Y110.173 E7.4996*85
11:27:44.481 : N1682 G1 X78.303 Y110.38 F7200*115
11:27:44.481 : ok 1677
11:27:44.481 : N1683 G1 X78.295 Y99.675 E7.8397 F3000*12
11:27:44.481 : ok 1678
11:27:44.497 : N1684 G1 X78.317 Y99.572 E7.84304*95
11:27:44.497 : ok 1679
11:27:44.497 : ok 1680
11:27:44.497 : N1685 G1 X78.353 Y99.516 E7.84515*90
11:27:44.497 : N1686 G1 X78.402 Y99.474 E7.8472*107
11:27:44.528 : ok 1681
11:27:44.528 : N1687 G1 X78.47 Y99.454 E7.84946*99
11:27:44.575 : Error:Wrong checksum
11:27:44.575 : Resend:1682
11:27:44.606 : ok
Printer is printing 10-30s than breaks for 2-3s and continues printing.
