BL Touch but keep Z max home
I need to keep Z max multi home but run Auto bed level with BL Touch separate.
I have BL Touch on Zmin.
Also what does Extruder is Z probe do? and What can i use Servo control in UI for and where in UI is it?
Many thanks
Many thanks
extruder is z probe is exactly that. If extruder has a switch triggering bed hit. Has some special handling if you have 2 of them to calibrate z differencebitween them etc.
z probe on z min is ok, but set z min endstop to false ig you do z max homing.
It would take a 7 "10"
compliments
Y is running on 2 separate drivers at 640 steps per mm so it carn't be over heating and cutting out both driver at the same time. Could it be crosstalk or firmware bug?
Overhang miss looks straight so must be something affecting both drivers at the same time...
Distortion.h won't compile in Arduino its the first time ive used the distortion correction so how do i get it to compile?
